Question about GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White
There is a leak that periodically happen in the lower left hand corner of the freezer. about every two days. what does this and how do I fix it?
  • GE Master
  • 3,361 Answers
The defrost drain is frozen shut.
Turn off the refrigerator.
Remove the lower freezer bins to access the drain opening.
It is on the back wall of the freezer about 8 inches up from the bottom.
Chip out visible ice.
Use a hair dryer to melt the ice in the drain hole.
Posted on Jul 11, 2010
Whirlpool refrigerator is leaking cold water from the lower left hand corner.
Behind the refigerator are valves and water hoses going to the water dispensor and the ice maker. Anyone of these hose could have a leak either at the connection or the hose. I would not attempt at repairing this unless you are real familar with this problem or appliance repair man.
Feb 16, 2013 | Refrigerators
Water coming out freezer door
The drain is clogged on the freezer defrost line. They put a little rubber pinched nozzle on the end of the line which causes the problem. I removed mine and cleaned it but decided to leave it off. Unplug the freezer. You will need to completely defrost the freezer to get the ice completely cleared from the drain hole. Then remove the lower back panel and reach up under the center of the freezer, following the drain trough up from the drip pan. When you feel the rubber nozzle you can easily pull it off. Clean the gunk out of it and decide what you want to do with it. I'm hanging on to mine in case I see a need to replace it. Just did this today. Took about 3 hours including defrosting slowly with a hair dryer on low. Also took a short nap in between.
Aug 28, 2012 | Kenmore Refrigerators
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
Water leaking from small tube in back
It could be the defroster working and the water run off.?
Jun 09, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Water leaking from the left lower corner of the freezer
there is a drain at the bottom of the evaporator in the freezer section which is blocked,pour some hot water into the drain and that may unblock it
Jun 07, 2009 | Frigidaire FRS26ZSG
Water leak front left corner of freezer.
Your defrost drain line in the freezer is frozen closed.
You must turn off the fridge.
Remove the visible ice.
Use a hair dryer at the drain opening in the lower back of the freezer to melt the drain line ice.
Mar 11, 2009 | Electrolux Refrigerators
Refrigerator leaks water
most likely you have a plugged drain int he freezer compartment. if yo will look under and behind the lower basket in your freezer you will most likely see a bunch of ice build up. clear this ice out then you will see a drain hole in the center section behind the metal cover in the rear try to get some hot water into this hole to clear ice and to clear the drain then u shoul be good to go. thanks for using Fix Ya Peyton
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
When browsing page goes very small in top left hand corner
this happen when you shrink the browser page and close it without maximized it.
open the browser page, click and drag the page to the left top corner of the screen (top left corner of the browser page is at the top left corner of the screen).
move the mouse to the right lower corner of the browser (the arrow will change to 4 direction arrow). click, hold and drag the corner to the lower corner of the screen.
close the browser.
the browser page should be full screen when you reopen the page.
Dec 30, 2008 | Microsoft Windows Vista Ultimate Edition
Kenmore Bottom Freezer Ice maker installation
in the bottom style freezer the plug will be in the upper left hand corner of back of the freezer ,,, may have a cover plate over it but thats where it is and should be a couple small holes with plugs on the upper left hand side for the mounting screws / larry
Dec 11, 2008 | Kenmore 53642 / 53644 Side by Side...
GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White Logo
81 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
