Question about Texas Instruments TI-83 Plus Calculator
WILL NOT SHUT ON
My calculator has been replaced with new batteries and willnot turn on. any suggestions?
thanks
  • kakima Jul 11, 2010
    TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
    If that does nothing, remove all four AAA batteries. Press and hold the ON key for at least ten seconds. Replace the batteries. Turn the calculator on.
    Does that do anything?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having received no response in over a month, I assume it was merely a matter of the screen contrast.
Posted on Sep 07, 2010
How to reset calculator
Dear
generally the calculator auto reset but some manufacturer provide a reset switch, its found at back side of the calculator by noticing a pin hole and either embossed or engraved RESET.
But i may suggest to recheck the battery contact points and orientation.
Thanks.
Jan 05, 2015 | Office Equipment & Supplies
My calculator just shut off while i was using it, i replaced the triple A batteries but now it still won't turn on, how can i fix it?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and hold the 2ND key. Press and hold the + key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Mar 15, 2012 | Texas Instruments TI-89 Calculator
My calculator will not turn on. I replaced the batteries with new ones and it still will not turn on.What can I do to fix it?
Receiving no response in five months, I assume my suggestion to adjust the screen contrast solved the problem.
Oct 21, 2010 | Texas Instruments TI-83 Plus Calculator
Does the calculator rely completely on solar Not turning on Do you have to change battery
The calculator uses a battery in addition to the solar cell. If the battery runs down you need to replace it. Turn the calculator over and you'll see the battery compartment in the upper-right corner (with a screw holding it shut). The calculator takes a LR44 battery or equivalent.
Make sure you clear the calculator after replacing the battery: press ON SHIFT 9 3 =
Aug 25, 2010 | Casio FX-115ES Scientific Calculator
My calculator completely shut down and now I cant turn it on. I tried taking out the batteries but that was no the problem!! what should i do?
Be sure the contacts for the batteries are clean, shiny and free of any corrosion.
To be absolutely sure it is not a battery problem, replace the old ones with fresh new ones. Mine is pretty finicky too.
Mike
Feb 09, 2010 | Texas Instruments TI-83 Plus Calculator
Would randomly shut off
Listen! I am no seer, but I suspect that the batteries in your calculator are depleted. Replace all of them because the backup battery is not able to keep the flash memory refreshed.
Hope it helps.
Dec 07, 2009 | Texas Instruments TI-83 Plus Calculator
Frozen display and keyboard after battery replacement
Press [ON] and [CLEAR] at the same time to reset the calculator
  1. if you get unexpected results or
  2. it refuses to turn on, or
  3. screen goes balnk.
Apr 19, 2009 | Texas Instruments TI-34II Explorer Plus...
Minimally used calculator drains batteries fast
The draining of batteries depends on usage. Turn calculator off when not in use. Use rechargeable batteries: Have two sets of them and change batteries before the ones in use are not fully discharged.
If you get tired of that, I suggest you have the calculator repaired.
Hope it helps.
Apr 14, 2009 | Texas Instruments TI-89 Calculator
Calculator will not come on at all
Replacing the battery will always do good. You will be assured that the problem you may be having is not due to spent batteries, so that you may focus on other potential causes.
Hope it helps.
Jan 23, 2009 | Casio FX-300MS Calculator
Convection side of this microwave oven willnot turn off at prescribed setting
I sought some advice from a local technician with this problem and he suggested to replace the thermistor with a new one, which I did and problem solved. I thank you with this response as it may have needed more follow up. I will definitely book mark this site, and suggest to others about you, Thanks again.
Jul 10, 2008 | Sharp Microwave Ovens
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
