Question about Kenmore Washing Machines
Kenmore stylemaster 909964 80 series. will not agitate or spin. please help
  • Kenmore Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinekenmore stylemaster 909964 - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jul 12, 2010
I have a Kenmore model stylemaster 909610. It fills normally, but doesn't agitate properly, it moves, but barely, no odd noises or anything, just barely agitates and the clothes don't move it's so weak....
If you can move the agitator in both directions, you may just have some bad agitator dogs. They are located under the dispenser cap, below another cap and remove a 7/16 bolt to replace.
Jul 01, 2014 | Washing Machines
Kenmore stylemaster 902202 will not spin, agitate or drain tub spins freely
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 07, 2013 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 90 Series washing machine Stylemaster 4217017. It quit spinning tonight. How do I fix it?
Possible that the belt or the drive or the spindle assembly is the suspect. Click this link for tips to reset: Drum Reset
Jan 19, 2013 | Kenmore Washing Machines
Problem with a Lady Kenmore Model 902202
You might as well go ahead and replace the machine, the cost to repair this problem is going to shock you.
Jun 25, 2017 | Kenmore Washing Machines
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
340 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
