Question about Keurig Elite B40 Coffee Maker
When starting all lights flash off and on continuosly
No water leaves the resivour
  • Keurig Master
  • 1,711 Answers
Here is a sugestion tip that will help
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Good luck thanks for voding
Posted on Aug 10, 2010
Saeco intuita- performed clac/ clean, and now calc/ clean fast flashes. Pressing only goes to slow flash and water dispensor light fast flashes.
Use a paper clip to clean the Needle that penetrates the Kcup. If it still happens call 1-866-901-2739 for direct assistance.
Dec 29, 2013 | Keurig B60 Coffee Maker
Intuita coffe machine not working
Needs a service take it in let them replace the seals,If the seals go faulty this happens
Dec 29, 2013 | Coffee Makers & Espresso Machines
When i turn on the machine the "!" flash fast constantly and the "drop"light turn on; i turn the nob for the hot water but nothing comes out no water or steam...nothing works..i can hear the engine runnin...
It is telling to purge the air in the water line. Make sure there is no filter in the water tank and turn on the knob. The pump should **** the water and let it out from the steam arm.Hope it works.
Oct 11, 2010 | Saeco Odea Giro Plus Coffee Maker
Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Oct 19, 2009 | Indesit Washing Machines
Fault code f90, door lock light keeps flashing and then the oven beep continuosly.
maximum oven door unlock time exceeded. Check wiring between eoc & door lock micro switch. more likely you need to replace the EOC
May 19, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
I have a schaerer opal coffee machine, when I switch the machine on, the water light flashes, and a pump runs continuosly as if it is trying to purge the machine. but nothing comes through. does anyone...
I have a schaerer opal coffee machine, when I switch main power machine on, the descaling indicator, cleaning/rinse indicator and stand-by mode indicator lamp remains lit, and a pump runs continuosly. the machine do not ready mode indicator. Yudi INDONESIA
Apr 05, 2009 | Schaerer Opal Espresso Machine
Saeco Italia water lite and green lights flashing
Try to open the steam knob and make a cup of water (tea), see if you can get a full cup or just a half.
How old are your machine?
How often do you descale the machine?
Best regards
/Mirran
Sep 05, 2008 | Starbucks Saeco Italia Digital Barista...
I'm having problems with my Bodum granos it is not dispensing water for esspresso or manually. It starts to go through the process it then shoots out alot of steam and then stops. The indicator light...
I had a similar problem and had a techo fix it.  He didn't charge - because the solution was real easy. Basically you have a blocked filter. The filter is at the base of the rear column. You need to unscrew the back plate on the column leading up to the head. Once unscrewed you'll find the filter somewhere at the base end. Remove filter wash, reinstall and screw the thing together. Should now run ok. Cheers
Apr 03, 2008 | Bodum Granos 3020-16 Espresso Machine
Saeco italia error
What happens when you open the knob on the right? It may just need priming.
Jan 21, 2008 | Starbucks Saeco Italia Digital Barista...
Keurig Elite B40 Coffee Maker Logo
344 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
