Question about Hitachi 27CX31B 27" TV
Hitachi PIP TV Model 27CX31B very low volume connected to DirecTV however when checked for problems, volume is fine when not connected to DirecTV
  • 18 Answers
SOURCE: hitachi 53fdx20b rear projection color tv with no picture
Reset tv to factory settings refer to your owners manual. If still no picture attach a DVD or video player and test. If still no pic refer to tech.
Posted on Jan 05, 2008
osborne382
  • 306 Answers
SOURCE: hitachi 55vf820 problem
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Posted on Mar 17, 2008
  • 1779 Answers
SOURCE: Hitachi screen scrolling
Are you using the AV outputs on the Receiver and not the composite grn-red-blue. Do you have the converter jack on the back by the ant. input? what souce on the set are you using for PIP and your main screen?
Posted on Mar 20, 2008
Will not turn on. TV is pluged in its almost like a power surge. The power bar is lit so for some reason the tv is not getting power.
imend
  • 66 Answers
SOURCE: i cannot connect my direct tv
The S-Video connections have the same 4 prongs & 1 plastic guide always. You are trying to plug it into a factory-service port on the bottom (looks similar to S-Video, but it's not it). Instead, connect the S-Video wire to Input 3 on the back of the AVC (Audio Video Control Center). The AVC is the box that came with the TV.
Posted on Apr 07, 2009
Auria TV Losing Zoom Setting Upon Power Up
The TV adjusts to the incoming signal automatically, that is normal
Jun 13, 2018 | Directv Televison & Video
Hello I can hardly hear on all of my channels. I have directv and I can't get a reasonable volume. Is there something I can do to fix this problem?
Directv low volume problem.
One sure way to eliminate Directv's low volume and any other volume problems in general is by installing a stereo compressor between your Directv receivers audio outputs and your TV's audio inputs. (Simply plug the compressor's outputs into TV and your receiver outputs into the compressor's inputs). By correctly setting the controls on the compressor, you won't loose the dynamic program content. Not only will it raise the volume level to where you want it be, it will also prevent it from exceeding any set level you chose, actually limiting how loud any sound can be. These settings are fully adjustable. In other words when you switch from Directv back to a dvd or any source, no more sound blasting, you can set levels to be the same now since you have raised then adjusted Directv's level to normal. Plus a compressor will raise those low hard to hear audio sections often found in movies. This is the reason we used them all the time in the recording industry. Another benefit is it levels all channels on Directv. The result, channels are now the same volume. This is what I'm doing to end the problem. Hope this helps someone. J Pynckel
Jul 27, 2010 | Directv H21 DTV Receiver
Can't get DirectTV rc65 remote to program the tv volume and power, tried all the codes.
Cant connect RC65 to Samsung 46" LED TV or Panasonic Blue Ray. Have followed instructions and tried all codes. no luck :(
TV model is: UN46B6000
Blue Ray is: BDP-120
TXS
Nov 28, 2009 | Directv RC32RFK Remote Control
Low volume on Direct TV channels
This is a known and ongoing problem with Directv since June. They claim they are trying to "level" all the channels so they are the same volume level. The result so far is that ALL channels are suffering from low volume. Given this has been going on for two months now, Directv may never solve this - General ineptitude - denials - but if you call and tell them you are having low volume, they will give you a three month $5 credit. CALL and COMPLAIN... the only hope we have to get this fixed is to cost them money and time on their customer support lines.!!!!
Jul 20, 2009 | Directv H21 DTV Receiver
I cannot connect my direct tv
Apr 07, 2009 | Hitachi Televison & Video
Directv remote increases volume slowly
The Direct TV remote has to be programmed properly. See the user manual for the process. The problem is, the user manual tells you to enter a code for the TV, but gives you a long list of codes that may work. So it's simply a problem of trial and error. For me, the first code in the list gave me the same results that you got (having to press volume repeatedly). But when I programmed the 2nd code in the list, pressing and holding the volume worked!.
I can't guarantee it, but I suspect you'll have the same result.
Feb 13, 2009 | Samsung TV Remote Control
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Program Code
DIRECTV Model D-10 00001, 00002
Hughes Network Systems (most models) 00749
Hughes Network Systems models GAEB0, GAEB0A, GCEB0, GCEB0A,
HBH-SA, and HAH-SA 01749
GE models GRD33G2A and GRD33G3A, GRD122GW 00566
Hitachi model HDS210R 00819
Mitsubishi HD models SRHD400 and SRHD500 00749
Panasonic models TZ-DBS01 and TZ-DRD100 00247
Panasonic models TUIRD10 and TUIRD20 00701
Philips models DSX5150R,DSX525R/I, DSX5350R, DSX5353R,
DSX5353X, and DSX5375R 01076
Philips models DSX5500 and DSX5400 00099
Proscan models PRD8630A and PRD8650B 00566
RCA models DRD102RW, DRD203RW, DRD301RA, DRD302RA,
DRD303RA, DRD403RA, DRD703RA, DRD502RB, DRD 503RB,
DRD505RB, DRD515RB, DRD523RB, and DRD705RB 00566
RCA models DRD202RD, DRD221RD, DRD222RD, DRD223RD
DRD225RD, DRD420RE, DRD440RE, DRD460RE, DRD480RE,
DRD430RG, DRD431RG, DRD450RG, DRD451RG, DRD485RG,
DRD486RG, DRD430RGA, DRD450RGA, DRD485RGA, DRD435RH,
DRD455RH, and DRD486RH 00392
Samsung model SIR-S60W 01109
Samsung models SIR-S70, SIR-S75, SIR-S300W, and SIR-S310W 01108
Sony models (All models except TiVo and Ultimate TV) 01639
Toshiba model TSR101DSS 00790
Uniden model UDS100 00724
Setup Codes for DIRECTV HD Receivers
DIRECTV Model H-10 00001, 00002
Hitachi model 61HDX98B 00819
HNS models HIRD-E8, HTL-HD 01750
LG model LSS-3200A, HTL-HD 01750
Mitsubishi model SR-HD5 01749, 00749
Philips model DSHD800R 01749
Proscan model PSHD105 00392
RCA models DTC-100, DTC-210 00392
Samsung model SIR-TS160 01276
Samsung models SIR-TS360 01609
Sony models SAT-HD100, 200,300 01639
Toshiba models DST-3000, DST-3100, DW65X91 01749, 01285
Zenith models DTV1080, HD-SAT520 01856
Setup Codes for DIRECTV DVRs
HNS models SD-DVR80, SD-DV40, SD-DVR120,
HDVR2, GXCEBOT, GXCEBOTD 01442
Philips models DSR704, DSR708, DSR6000,
DSR600R, DRS700/17 01142, 01442
RCA models DWD490RE, DWD496RG 01392
RCA models DVR39, 40, 80, 120 01442
Sony model SAT-T60 00639
Sony model SAT-W60 01640
Samsung models SIR-S4040R, SIR-S4080R, SIR-S4120R 01442
10
PROGRAMMING
Jan 26, 2008 | Directv RC23 Remote Control
Dec 10, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
