Question about Pool & Spa
The LED displays the letters 'dr' flashing & 'SnS' flashing what does this mean because my spa is full but will not heat.Also when the electrician came to power up the spa he's just ran it off a standard wall powered socket instead of wiring an independant power source from the household powerbox. could this be a problem? electrician said the worst thing that would happen is the fuse would blow in the household power box.Could this be a problem?
    Scholar:
  • 78 Answers
First, get a new electrician. Circuit should be a dedicated one, GFCI protected.
Next, the dr means the heater doesn't have sufficient water in it. The SnS means the sensor is out of balance. If the SnS is blinking, it just means the spa is shut down, more than likely because of the dr message...Check all your valving to make sure the heater is not isolated..
Posted on Jul 13, 2010
Down east spa showing SnS Pumps working. Cleaned filter. Turned power off for an hour. Still getting SnS and no heat. Help?
check recirculation pump and heating element and safety circuit pressure switch if ok temp sensor
Dec 12, 2017 | Pool & Spa
My Leslie copper therm pool heat fires, then turned off and LED says sns. What is wrong model P-l400A-EN L400A-EN
I think sns means sensor, perhaps the over temp sensor is defective, that would cause the shut down.
Sep 21, 2016 | Pool & Spa
Getting a sns code on control panel display. Where is the sensor located on this pool heater?
In the header... Plumbing side
And wire plugs onto heat / control assembly board.
SNS indicates that the Temperature Sensor is out of range! There are two thermistors within that sensor, and if there is a difference of 2 degrees, the board will throw a Fault Code: SNS
check for good connection at board, and ensure the sensor is all the way seated properly in its well.
otherwise, it may be bad.
Apr 25, 2015 | Rheem M266A 266K BTU Pool or Spa Natural...
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Display is reading sns. what does this mean?
SNS 1) SENSOR IS FAULTY
2) TEMPERATURE IS ABOVE 110°F
3) TEMPERATURE IS BELOW 36°F
It is one of the above situations
Apr 27, 2011 | Raypak 2100 Pool Heater Gas 336000 BTU'...
Rheem 206 propane heater will not fire has code #sns what is the problem? the water is 65 degree.
SNS means the temp sensor is out of acceptable range. Could be the following:
1. Water temp is below 36 degrees F
2. The sensor contains 2 thermistors, if they are more than 2 degrees apart and SNS failure will occur
3.Loose or corroded connection at P1 on the main board
4. If the sensor has come out of the JACO fitting on the header, it may read a SNS failure.
Solution, visually inspect the connections for corrosion. If it looks ok, then replace the temp sensor.
Jan 01, 2011 | Rheem M206A 206K BTU Pool and Spa Propane...
When I put power to my unit. A Sn code appears. Great Lakes spa 1996 260E balboa wiring
If the SnS or Sn Message is Alternating with the Water Temperature on the Display, it is a Possible Sensors Out of Sync Message.
If the SnS or Sn Message is Blinking or Flashing OFF and ON without showing Water Temperature, it is a Verified Sensors Out of Sync Message.
http://service.balboa-instruments.com/ErrorCode/ for code info
Dec 06, 2009 | Balboa Instruments Garden
Pool & Spa Logo
188 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
