Question about Delta Faucet Plumbing
Delta side spray replacement
Need to determine replacement side spray. Can anyone tell me the difference between Delta items: RP31612, RP28900, and RP39345.
  • 760 Answers
Delta makes sprayers to match the faucet design. Functionally they're about all the same. GO to theirr web site: http://www.deltafaucet.com/customersupport/index.html
If you don't know your model number you can use their wizzard and identify your faucet model. Then go to the parts section. One difference on the number you listed is I believe on comes with the mounting fitting that attaches to the sink. Some don't have it if they go through the faucet base itself.
Delta faucets have lifetime guarantee, I'm not sure if that includes the sprayer. (I doubt it)
Posted on Jul 11, 2010
  • Donna Hamilton Jul 13, 2010
    I did call them today before receiving your comment. And the parts had lifetime warranty. It turned out my model was discontinued in the Classic series with the side Thank you anyway.
Delta kitchen faucet
Could be mineral deposits or o-ring that needs lube.
May 16, 2013 | Delta 2402 Classic Single Handle Kitchen...
Re Delta faucet 172-WHWF The spray assembly has a long delay in getting water to it. Would a new diverter valve fix that problem? If so, what is the part number for the diverter valve for this...
Before you start replacing parts look under the sink and make sure the hose leading to the remote spray is not kinked or starting to kink when pulled out.
Mar 07, 2011 | Delta Faucet Delta 172-WHWF Waterfall...
I have a delta love 2002 4925. has it been recalled? if so what is the problem? How do I fix it?
Most drop side cribs have been recalled.
You can read the details of the Delta recalls here. This is their website and you can access information on fixing the problem and getting an immobilization kit.
Basically, almost all drop side cribs have been recalled and it has been determined that they should not be drop side anymore.
Here is the official information:
Delta Recalls to Repair Drop-Side Cribs Due to Entrapment, Suffocation and Fall Hazards
Jan 24, 2011 | Delta Luv Delta - Baby Products 5-in-1...
I wanted to find out if the delta marine crib was recalled
There have been Delta Crib recalls. To determine if the Marine is one of the recalled models, go to www.cpsc.gov - the U.S. Consumer Product Safety Commission web site.
This is a recent document on Delta Crib recalls:
www.cpsc.gov/CPSCPUB/PREREL/prhtml10/10273.html
From the above document: This recall involves Delta drop-side cribs with three different types of drop-side hardware and Delta cribs with wooden stabilizer bars that support the mattress platform. Consumers should visit www.cribrecallcenter.com for photographs and models of the affected hardware types and instructions on correct assembly of the stabilizer bars.
Oct 04, 2010 | Baby Gear
I have a Delta Luv Crib Model 4885, Order No. W24255 Date Nov. 2004. Is there a recall on this crib?
Luckily I didn't see your model listed in Delta's Crib Recall. Below is link to Delta's website and a list of all Delta cribs recalled.
http://www.deltacribrecall.com/
If this information is helpful, I would really appreciate a "thumbs up" rating!!
Delta cribs manufactured in Taiwan or Indonesia, with the “Crib Trigger Lock with Safety Peg” drop side hardware design, numbers:
4320, 4340, 4500, 4520, 4530, 4532, 4540, 4542, 4550, 4551, 4580, 4600, 4620, 4624 (production dates 01/06 thru 11/07), 4640, 4660, 4720, 4735, 4742, 4750 (production dates 01/95 thru 12/00), 4760 4770, 4780, 4790, 4820, 4840, 4850, 4860, 4880, 4890, 4892, 4900, 4910, 4920, 4925-2, 4925-6, 4930, 4940, 4943, 4944, 4947, 4948, 4949, 4950, 4958, 4963, 4968, 4969, 4980.
Delta drop side cribs manufactured in China through 2005, with the “Crib Trigger Lock with Spring Peg” drop side hardware design, numbers:
4340, 4343, 4520, 4600, 4620, 4624, 4625, 4629, 4660, 4665, 4720, 4750, 4751, 4850, 4855, 4857, 4880, 4920, 4925-2, 4925-2B, 4925-6, 4980, and 8605.
Aug 10, 2010 | Delta Luv Delta - Baby Products 5-in-1...
DELTA SINGLE HANDLE GOURMET SPRAY faucet
Hello. Actually it is not difficult to remove the faucet. If you can pull up the sink with faucet attached it will be very easy. Otherwise get under the sink with a flashlight and you will see what tools are needed. A special extendable faucet wrench from Home Depot would come in very handy. Regards. Joe
Jan 14, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Plumbing Logo
689 people viewed this question
Top Delta Faucet Plumbing Experts
Steve Wood Plumbing...
Level 1 Expert
joeiaaz
Level 1 Expert
doconnell13
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
