Question about Honeywell Consumer Products Model CT87A-4009 Mechanical Heat-Only Thermostat Heater
Ct87a 4447 thermostate tempature is off, how do
Model # CT87a 4447 honeywell thermostate tempature is off, how do you reset or do you just buy a new one/
How do I get into thermostate to change battery honeywell an older model
Rotate upward from bottom to release the catches at the top.
Sep 27, 2018 | Honeywell Heating & Cooling
How to reset thermostat
as it is a honeywell product and the new second one didn't work it is not for fixya site to fix but as the new part is still under warranty then it is up to honeywell agents to come and fix under warranty
if push comes to shove talk legal,action as it is the company's responsibility to fix faults of new products under warranty
It was not even up to you to buy a new part as it should have been replaced free
May 28, 2017 | Water Heaters
How do you reset the +- tempature on a honeywell thermostat
what is the model number of your tstat.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Dec 02, 2017 | Heating & Cooling
Where can I purchase replacement water filters for LG Refrigerator Model RS2630SH as soon as possible? I assume actually replacing the filter is self-explanatory? Thanks. Jane
Hi Jane and welcome to FixYa. I am Kelly. Since you did not mention a geographic location I am assmuing somewhere USA. For some reason the model is crossing to a Samsung Refrigerator and not an LG one. I am using RS2630SH as the model number and keep getting Samsung results.
Searching Samsung there is one filter here:
http://www.searspartsdirect.com/partsdirect/subcategories/6117/4447/Samsung
LG there are 3 filters here:
http://www.searspartsdirect.com/partsdirect/subcategories/6054/4447/LG
Here is something to think about.... Once you do install a new internal filter. I recommend installing an external in line filter. The are cheaper... and will make the internal filter last 5 - 6 times longer.
Kelly
Jul 07, 2011 | Refrigerators
I need an operating manuel for honeywell thermostate 52-8848-2
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Apr 23, 2011 | Honeywell Heating & Cooling
Honywell whine chiller model 88058 not working
Hello friend, i had the same problem and it was solved replacing largest capacitors on board, they are 2 x 120uF(120V). You must to check that both original capacitors be damaged, you can to see it if they are inflated on the top
Jul 23, 2010 | Honeywell Consumer Products Model...
Have moved into a house which has a honeywell CM5000 heating system but dispite resetting the time date and temperature in each room it still won't start.Have had the airconditioner on during the summer...
dont know the square footage of your home or how many units you have. unless you are in and out of your home for long periods of time and need a digital thermostate. get rid of it. install a 30 dollar honeywell or call a prof. to f@##$%^you.
Apr 25, 2009 | Honeywell Electronic Programmable...
What do you set the heat anticipater setting at on a ct87a honeywell thermostat. My furnace is a Miller cmf80pg gas furnace?
Go to the gas valve and look on the valve it will tell you the rating. Set the adjustable heat anticipater on the thermostat to that. Look for something like .54 amp or .35 amp. If you have a amp meter you can make a 10 wrap and get it that way but that is too much work. ken
Jan 26, 2009 | Heating & Cooling
Heating & Cooling Logo
254 people viewed this question
Top Honeywell Heating & Cooling Experts
Paul Carew
Paul
Paul
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
