Question about Shuttle K45 Intel based barebone system Motherboard
My Shuttle K45 recently stopped working (fan runs,no power light)
My Shuttle K45 recently stopped working (fan runs, no power or drive light, no video). I tried replacing the power supply & the CPU (socket 775 Intel Celeron), but so far nothing has changed. I had read in a post elsewhere where someone had this problem & installed a PCI video card which resolved the problem- tried that, still no luck. At this point I am suspecting that I will have to replace the entire motherboard, but it is hard to find a site online that sells replacement motherboards. I hadn't tried Shuttle directly as I didn't see where they sold these in prior visits there. Any ideas would be greatly appreciated-
Thanks in advance,
Fred Williams
  • 206 Answers
There may just be a short in your board of a device connected to your board as u said the previous problem was solved by video card as it was because the video card was faulty which was giving the problem!!
so before going in for a new board try to check each and every part separately u might find the faulty part or then it may be the boards problem!!
because if without checking all the devices if u get a new board and then u find the problem still and because of just some device then it will be a waste!!!
so try this, reply and rate me!
Posted on Jul 11, 2010
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
Optiplex 320 wont boot. Amber power light and fans running
power off 1st..then open ur cpu ..check ur ram ...and clean it....or mother board is not work replace near hardware shop....or check ur bios bettery or change it
Feb 17, 2012 | Shuttle sn Computers & Internet
Shuttle SG41 - J1 - New build, no video output, power light on, fan running. Removed & tested CPU (intel Pentium D 2.8G), it's OK. RAM OK.
Hi, I have exactly the same problem and done the same checks as you. Did you manage to resolve it and if so can you please tell me ho?
Thank you
Jul 18, 2011 | Shuttle SG41J1 Plus SG41-J1-BK-VP-H...
My computer cannot turn on the power, and i found a red led always on at the center near the rear portion of the mother board. is that something wrong with the mother board or just the supple power is...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
Jun 26, 2011 | Shuttle K45 Intel based barebone system...
Audio driver
MY PC IS NOT PLAYING SONGS BECAUSE MY PC IS NOT HAVING DRIVERS I HAVE TO DOWNLOAD 945GCT MOTHERBOARD DRIVERS
Jan 31, 2011 | Shuttle K45 Intel based barebone system...
My Sony PCG K45 Laptops cooling fan runs continiusly after just a few minutes of powering up the system Why is this as it is not normal
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Oct 10, 2010 | Sony VAIO K45 Notebook
CD Shuttle stops
Run a laser lens cleaner thru it, if it still fails, replace it. chances are parts will be hard to find. Check with a local Alpine Dealer for estimate and they can tell you which is your best available option. Hope this helps
Sep 21, 2009 | Car Audio & Video
No power to motherboard Shuttle AN35n ultra
Hi there
Try One of the following steps:
  1. Flash Youre MB BIOS.
  2. make sure that CPU Fan is working OK.
  3. Is the CPU attached to the MB correctlly.
  4. Is the CPU Fan base and scrowse faremly scrowd and positioned on the MB.
  5. Chec MB in/pot power pins connections.
Hope That will Help.
May 16, 2009 | Shuttle AN35N Motherboard
Shuttle ab45 v1.2 motherboard, the pc monitor doesn't light up
hi im josh in cebu phils.may i help you. Friend your 478 mainboard doesnt work.? All you have to do is to check the hardware attached on it like hard drive video card memory and most of all the power supply cable.be sure you seated it very well to avoid loose connection. this can cause no display or not working. try to check alson if your pwer supply has enough current to support the mainboard and alson the processor compatiblity with the mainboard. good luck hope i helped you.
Feb 20, 2009 | Shuttle AB45 (SHUTAB45) Motherboard
Shuttle XPC - fan on the back does not stop
I would suggest you have a fan with faulty bearing
and i thing the power supply could want changing
Sep 01, 2008 | Shuttle first SFF barebone with the power...
Shuttle K45 Intel based barebone system Motherboard Logo
511 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
