Question about Golden Technologies Golden Liteway 3 Wheel Scooter
Can you replace a brocken axle shaft that goes into the scooter m
Can the moter that goes into the axle shaft be replaced?
  • 177 Answers
Hi. Why do you need to replace the motor? Very few motors completely burn out. Most suffer from stuck or worn brushes, and these can be fixed.
Some scooter companies will only supply the complete transaxle assembly, which makes it expensive.
What fault does you machine have, and how old is it?
Good luck. Neil.
Posted on Jul 13, 2010
Just put in new batteries ines my go go traveler scooter and now it just stops suddenly and then goes and stops again. Should I also replace to fuses?
hi Paul, first of all check the battery connectors on the battery pack, making sure the battery packs fits nice and tight with no movement,
The axle part of the scooter, making sure the axle snaps to the frame nicely with no movement and check the connectors here as they are a big problem area, you're looking for discoloured connectors and poorly fitting ones...
I can supply you with all replacement connectors if required...
Regards
Rob
Oct 31, 2015 | Health & Beauty
What grease goes inside go go scooter transaxle
I searched the web as well as the manufacturers website where they post the specs for your scooter and everything says they are a seal trans axle which means you have to replace the entire thing and you don't have to worry about adding grease. if it's grinding or squealing it must be time to replace it
Jul 17, 2012 | Pride Go-Go Elite Traveller 4-Wheel Travel...
Husqvarna cth 180 the shaft as brocken on the rear axle can I replace it
to replace it you need to remove the rear assembly then open the rear axle assembly
Jun 16, 2012 | Husqvarna Garden
How do I remove the rear axle
The rear axle shaft?? Or the entire axle? I'm going to go with the axle shaft. Secure the vehicle. Loosen the lug nuts. Jack it up. Take the wheel and tire off. Remove the caliper and/or bracket. Remove the rotor. Place a pan under the rear differential cover. Remove the rear differential cover. Spin the axle shaft to reveal the center pin. Locate the 8mm-5/16 bolt that holds the center pin in place. Remove that bolt. Slide the center pin out, BUT DON'T TURN THE AXLE SHAFTS WHILE ITS OUT! Push the axle shaft in from the outer portion (where the wheel goes). A "C" clip will fall out inside of the differential. Pull the axle shaft out. Slide the center pin back in. Replace the 8mm-5/16 locking bolt and spin it a few times to keep everything in place.
Feb 23, 2011 | 2000 GMC Jimmy
My dad has a pride celebrity xl scooter and keeps getting a noise similar to a rubbing noise from rear right wheel while driving, it sounds once for every rotation of the wheel, iv checked that nothing is...
The noise you are describing usually comes from the trans-axle and not from the motor/brake. Motor brake noise is usually continuous. Sounds like the trans-axle may be slightly bent on the right or rubbing internally. The easiest way to identify this is to block up the scooter and remove the rear cover. Look and listen to all the drivetrain components while the scooter is blocked up and running. If you hear rubbing at the end shaft as you describe you can try the following:
Loosen the trans-axle metal mounts that clamp the rubber sleeves over the trans-axle
Spray the rubber sleeves with silicone.
Re-torque the clamps after checking the alignment.
An overtightened or misaligned clamp can sometimes cause noise.
The brake/motor/transaxle has a prorated three year warranty so you should go through a Pride dealer for warranty repairs.
Sometimes you can get a noisy wheel on the key and key-way of the trans-axle shaft. It may be worthwhile to pull both rear wheels lubricate the shaft key-ways and keys and re-install the wheels. This can sometimes quiet a multitude of noises from the trans-axle. Depending on the age of the scooter you can do nothing, replace the brake/motor/transaxle parts individually, replace the complete assembly. I like to replace the entire assembly under warranty so there are no future problems. The rest of the repair depends on your insurance coverage or budget. Hope this helps.
Nov 30, 2010 | Pride Celebrity Xl 4 Wheel Scooter
When driving my golden companion it makes a loud grinding noise. it sounds as if something is rubbing together. could it be a transmission problem
The problem you are describing is generally related to the drive train of the scooter. There are 3 components of the drive train:
trans-axle
motor
brake
The brake and motor looks like one assembly with the electromagnetic disc brake and freewheel brake lever mounted on the end of the motor. The trans-axle is aluminum color and has a drive wheel attached to it on either end. The trans-axle has a differential built into it to allow the scooter to take a turn. The motor is connected to the trans-axle with a plastic coupling. The noise you are describing is from several possible sources.
Take off the seat and rear cover . Block up the scooter to run it with the rear wheels off the ground.
If the noise goes away with the wheels off the ground, you probably have a bad/noisey trans-axle. If the noise is coming from the motor or motor coupling you could have a bad motor, bad coupling, or bad trans-axle. Watch for wobbling at the ends of the transaxle shaft at both ends.
A rubbing sound like a dragging disk brake means a bad brake. Further checks involve using a volt meter which involves some technical expertise. If you have a motor problem it is best to replace the motor/brake. If the trans-axle is noisy you can replace only the trans-axle.
Keep in mind if the scooter is fairly new some manufacturers warrant the drive train for upwards of 3 years, with a 30% per year allowance for the part price per year for the warranty period. Labor charge should be about an hour and is usually excluded from the warranty.
A good ear and a watchful eye will give you most of the answers you are looking for. Hope this helps.
Nov 05, 2010 | Golden Technologies Companion II Travel...
Noise on back axle
Is the noise like a stone stuck in the tyre? If so, I think you have a dry axle, a common problem with Pride scooters and easily rectified. Simply remove the rear wheels, apply grease to the axle shafts, and re-fit the wheels. This should solve your problem. If it's a different type of noise, the problem may lie within the transaxle which would unfortunately involve a costly repair or most likely a replacement transaxle.
Sep 27, 2010 | Pride Revo 4 Wheel Scooter
Golden Technologies Golden Liteway 3 Wheel Scooter Logo
88 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
