Question about Refrigerators
I purchased the lg French door Refrigerator on Feb. Model #lg LMX2598 1ST. There are 2 people living here and so I didn't notice how slow and disfuntual the icemaker is on this refridgerator. These past few weeks since my children have come to visit We ran out of ice everyday and it took forever to make more ice. i am so upset over this! I would never buy this Fridge again. I feel you should do something about this since I paid high dollar for it. Iwould not recommend sit to anyone.what can you do???? rebecca Landreth the
SOURCE: lg refrigerator LFX25960SW
the answer to the problem from a LG training class is... if the bottom left side of the refer is freezing food the liner has split no fix at this time. some people have beEn able to turn off the ice maker and the food will stop freezing. the ice maker has a fan in the freezer that blows all the cold air up the ice making Cobby.
DO THIS ONLY IF OUTA WARNTEE
for most of you with bad ice makers you could drill a hole in the very bottom of the ice maker towards the front right under the little metal arm in the wight plastic AND DONT DRILL DEEP just enough to put a hole in the outer case then hit it with a blow-dryer for a little bit to remove ice that's blocking the gear on that arm this works 5 outs 10 times
Posted on Oct 29, 2008
  • 221 Answers
SOURCE: LG refrigerator french door icemaker not working
The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jan 16, 2009
mark_37388
  • 100 Answers
SOURCE: kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Posted on Mar 30, 2009
SOURCE: Class Action Lawsuit against LG
My check for $ 16,- also said "Accepted as Full and Final Satisfaction of All Claims" despite LGs promise to make payments every year for the additional energy use. They never informed me that my fridge does not meet the "Energy Star" requirements. I won't cash this check and will wait for a class action law suit. I bought an appliance because I believed that I was doing something for the environment and then its like "sorry, you bought an environmentally unfriendly product and that you are destroying our environment but we will pay you $ 16,- to relieve your bad consciousness"
Posted on Jun 23, 2009
carlsbiz
  • 1124 Answers
SOURCE: My icemaker in my large French door Samsung
There is no way to speed it up..
If the bucket is empty - 2 to 3 days to fill is normal..
It takes somewhere around 37 minuets for new cubes to freeze,, then dump.. Cant make the ice freeze faster..
If it has a inline filter on the water line - replace it.. If it is clogged it could slow the water that is going in..
If you-all use allot of ice and empty it before it catches up - I would suggest getting a bag of ice from the store and put some in the bucket to keep the ice level up..
Have a nice day...
Posted on Sep 08, 2009
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
How do I remove shelves for cleaning an lg French door refrigerator?
On my Kenmore (795.7555* made by LG) French door, the adjustable shelves are removed by tilting them up and then bringing them forward. The sliding shelves and drawers just pull forward.
Which model LG refrigerator do you have? There may have been design changes between your fridge and mine. Please add a comment with the information for specific instructions.
I hope this helps.
(I didn't bother to give the full model number of my fridge since the directions also apply to the 795.7519* and 795.7554*)
Jul 06, 2012 | LG Refrigerators
LG french door refrigerator, model # FRFD22850TT, light stayed on and food was hot. Hoe do we get the light repaired? Also, frost builds up on Rt. side of freezer even with the door always closed, no...
the door switch control the light. check the switch
defrost thermostat and heat element control frost, check all of them
if u live near madison . wi , i charge u $100 fix the problem . part may be $100
Jan 13, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
The refridgerator is set at 40, & all the food freezes, especially in the bins. lg lfx25971
I had this problem for 2 weeks until I noticed the ice-maker door was shut but not completely. Make sure the ice-maker door is shut..hope this is your problem...
Aug 09, 2010 | LG LFX25971ST Bottom Freezer French Door...
Water flow of filter too slow
When was the last time you changed the water filter? If the filter is clogged from long usage it will slow down the water flow. Filters should be changed 6-12 months.
Jul 11, 2010 | LG LFX25971ST Bottom Freezer French Door...
LG French Door Refrigerator 3 door - Smoke out of Door Panel
Take out the freezer bins and look at the very rear of the freezer compartment. This is where your ice maker fan is. If it is caked with ice you have to defrost it. It's a pain, but it fixed my problem.
Mar 15, 2017 | LG LFC21760 Bottom Freezer French Door...
Refrigerators Logo
141 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
