Question about Garmin Nuvi 660 GPS Receiver
How can I get it to track sattelites? I've tried both the hard and soft reset.
  • Garmin Master
  • 2,130 Answers
Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Jul 13, 2010
My tablet won't come on I've had it charging so the battery should be full is there something I can do?
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
Jul 02, 2012 | Coby Kyros 716829701508 Tablet PC
I have a 03 yz 250 How much PSI do I put in my tires for racing track
The factory recommends 15PSI. I usually run 12PSI.
Depends a lot on what tires you have and what kind of "track" you are riding. You typically want a firm tire (more pressure) for a soft surface and a softer tire (less pressure) for a hard track but there are always exceptions depending on the details of the track and what tire you have mounted up. If you are riding a track with a lot of hard braking bumps or firm ruts or even tree roots (if you ride trails) you should run more pressure - like maybe 13-15PSI. If you run less than about 10PSI you risk pinching the tube and getting the rim damaged from sand intrusion between the bead and the tire which can cause a lot of problems unless you change your tires frequently and run multiple bead locks. To run really low pressures usually means you don't have the best tire on your bike for the conditions in my opinion.
To simplify:
Soft track, hard tire - run 12-15PSI
Hard track, soft tire - run no less than 10PSI
Sep 28, 2011 | 2003 Yamaha YZ 250
JVC KW-AVX 800 "Position error"
Assuming that this is not a new install (the laser is secured with a long, thin brass screw when shipped, and this screw must be removed on installation), and the unit has worked before today, then we will troubleshoot from the "damage" perspective.
The laser isn't centering itself to start position.
This could be due to track binding (dust buildup) or just a hard jolt to the base (pothole?), but the first thing to try is a soft reset...and if that doesn't get it, then a hard-reset next.
*Assuming of course that one of the kids hasn't jammed something foreign into the slot and knocked the head off-track...it happens quite often.
Soft reset:
Most models have a tiny, recessed "reset" button that you can press and hold for 5 seconds with a ball-point pen, located under the faceplate.
This will restore factory settings, and re-center the laser.
If the error returns, a Hard reset:
Disconnect the Positive(+) cable from the car battery for at least 30 seconds, and re-connect.
You will likely lose all saved stations on the radio, but this is a last-resort to avoid removing and opening the unit.
9 times out of 10 this will solve any digital errors, and will free sticky tracks better than half of the time.
Jun 29, 2010 | JVC KW-AVX706 Car DVD Player
I forgot my unlock code of nokia 6233 plz help me
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
Hope i`ve helped
Nov 25, 2009 | Nokia 6233 Cellular Phone
I´ve a pda hp h5455 that don´t start , i´ve tried to do a hard reset and charge it via USB and nothing hapens
To do the hard reset, while on battery (NOT A/C) power, hold down the two outside front-panel buttons (Calendar and iTask), While holding them, press the reset button with the stylus. Keep these buttons all pressed until the image on the screen begins to fade (about 4 seconds), then you can release the reset and application buttons. To restart your iPAQ, you must then plug the unit into A/C power, or do a Soft Reset by again, pressing the reset button with the stylus.
Nov 21, 2009 | HP iPAQ H5455 Pocket PC
Nuvi 350 finds satellites but won't lock on
Please read this solution, which might help you. On the Nuvi 350, press and hold the lower left corner while turning on.
http://www.fixya.com/support/t1155473-garmin_nuvi_660_not_locate_sattelites
- Jim
Nov 22, 2008 | Garmin Nuvi 350 Car GPS Receiver
Is there any way to record Tascam 2488 Multieffects directly to the hard drive when I record? When I change tracks during playback, the previous effect that I used disappears...Please help???
Yes. Rather than pressing the track SELECT button to assign the effect, press one of the SOURCE buttons to the left of the EFFECTS. This will record the effect HARD to the track as oopposed to SOFT. SOFT being that the effect will NOT be recorded whereas HARD means it IS recorded and will be there anytime you play the track. NOTE: Just make sure that's the effect you want as it is then part of the track.
Aug 21, 2008 | Tascam 2488 Portastudio Multitrack...
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
Forgot My Rassword
push the two - buttons along with the power and soft reset button.
Nov 26, 2007 | Sprint Vision PPC-6700 Smartphone
Garmin Nuvi 660 GPS Receiver Logo
74 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
