I have a DX-N350M (3 cd player since 1992). Absolutely no problems until last week. It started out not recognizing disc 1. It played 2 and 3. Then it didn't recognize 2. Now all 3 are not recognized. Everything else works fine. everyone is telling me it's about time to purchase new. However I would like to give it one more chance. Any suggestions. thank you for your prompt reply. carole laforce
techman
  • 3130 Answers
SOURCE: CD changer not playing CD's
If this did not help the problem by cleani9ng the lens, the laser is bad or the spindle moteo is bad. if this unit is over 2 years old, buy a new unit. Good Luck
Posted on Jul 15, 2007
  • 25 Answers
SOURCE: cd player does not work
yes this usually happens when the lens is too dusty, take a soft cloth like a shirt and gently wipe the l;ens that should work if not it is broken
Posted on Mar 04, 2008
SOURCE: CD Player not working
JANGO
THANK YOU! THANK YOU! THANK YOU! AFTER DOING WHAT YOU SUGGESTED, ONE OF THE TRAYS STILL WOULDN'T PLAY, SO I LET IT SET OVER THE WEEKEND AND NOW EVERYTHING WORKS GREAT. EVIDENTLY T HE LESE WASN'T COMPLETELY DRY, IS THE ONLY REASON I CAN THINK OF.
AGAIN MANY THANKS
SIPRESS
Posted on Mar 12, 2008
petraman7
  • 1175 Answers
SOURCE: 3 yr Old CD Player not recognizing discs
Laser might not be faulty but just a dirty lens/ rail assembly.
If thou darest open the thing, clean the lens ( GENTLY) with a swab of glass lens cleaner. Clean the chrome runners for the optics assby with a swab lcaed with WD40 or silicone.
Posted on Jun 26, 2008
SOURCE: doesn't recornize Cd's and won't play cds
I have a AWM-2700U (3 disc changer) that was doing the same thing. I removed the cover and found that the laser lens for the CD player had come out of it "slot". I cleaned it with alcohol and a cotton swab and replaced it in the slot and it has worked for the past 3 months since. Hope it works for you.
Posted on Dec 07, 2008
I have a 2003 Saab Arc and the 6 stacker CD Player will play and eject on all but no: 2 . Number 2 swallowed the disc and wouldn't play or eject it This the first time I've Tried to use the Cd player as...
Last radio I had that done the same problem I replaced the radio with an aftermarket radio and pulled my stock radio apart to get my cd out
Dec 22, 2017 | 2004 Saab 9-3
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
My Honda accord Sedan car CD Player cannot eject CD .
Before connecting any cables you must set the dip switch box to the position listed for your vehicle. If you set the dip-switches after you have connected cables to the box, you must disconnect and reconnect them for the changer to operate. All 1992-2004 Honda's are compatible with the Neo Changer except the 2003 and 2004 Honda Accord and all Honda Element vehicles. Some radio models require pressing "Seek >" once to start playing after changing CD or after startup. The radios display will not show the proper disc number after disc six. You can use all 10 discs in the magazine, but the readout will be wrong. This is not a technical problem; the car stereo was designed for no more than six discs. *Due to the direct access disc system, you will not be able to directly access discs 7-10. To access these discs you will have to go to the last track on disc 6 and let it play until it loads disc #7. ( you can fast forward the track, but you must let it play the last 5 seconds of the track, for it to change to disc # 7 Switch to the Neo Changer by pressing the "CD" button. To change discs press "Disc -" and "Disc +" To change tracks simply press "Seek <" or "Seek >" S E T T I N G S F O R H O N D A 1 2 3 4 5 6 7 8 ON OFF OFF ON OFF OFF ON OFF
Dec 21, 2010 | 2000 Honda Accord
Discs not reading
first clean the laser lens,and if this not solve your problem change the motor disc spindle
Jul 13, 2009 | Onkyo DX-C340 CD Player
Onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
May 07, 2008 | Onkyo DX-C390 6-Disc CD Changer
64 people viewed this question
 Grubhead
Grubhead
