Question about Metra Line Output Converter
Lost my instructions
I just need to know what 4 wires on the back of my stereo I will connect to the av output convertor box
HOW I CAN HAVE OUTPUT FRO AUDIO LINE ROM LG 55LH5000???
Hi, sorry but Most LG's no longer have audio outputs. The easiest way to get it ,You need to take the audio output from the source i.e. "cable box output"..if you have of course...
However whether your TV has this output or not we need to make some tests..5 different connections possibilities provided below.
(not by priority..you can start with any of it ).Below ,there is a sample TV back panel picture as well
Possible CONNECTIONS:
1) 2x RCA ports red / white is audio out ( L + R ) of TV to Stereo..
2) You can get also the audio digital output from the TV to a A/V receiver. the tv's optical audio out is stereo only mainly designed for freeview or tv audio to be output,
set the audio ouput on the TV menu to Dolby Digital, connect a digital optical out directly to the A/V receiver to receive audio signals.
3) since your TV has :2 x HDMI, SCART, AV, Component Video, VGA-sub, USB 2.0, connections,you may use the SCART plug to get Audio output for your TV .
TV's SCART connector which has 21 pins and "2x Audio Output " pins should be in it.
you need to buy an adapter called " RGB Scart Male to 3 RCA AV Female Adapter Converter" that can easily be found any electronic Market..one example as found eBay URL is below..
http://cgi.ebay.com/RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter-/130389078197
After you get this adapter,you need to carry the audio signal from SCART's RCA plugs to your Receiver with a 2x RCA (white/red ) cable.(if this does not work ,mfg should state somewhere in the manual..as your TV's "SCART socket IN only" ) if you properly connect IN/OUT plugs you will able to get the audio signal of the TV thru stereo..I recommend 2 $ value "RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter" with IN/OUT switch on it.
4) use HDMI connection of TV if you have HDMI input on your stereo of course...
5) if these are not an audio-out on one of these connectors , so you'll need to use the headphone socket if you want to plug it into a stereo. you need a cable 2x RCA to 3.5mm Headphone jack.
( This is the last ditch solution , since it mutes the whole sound.) ..
NOTE: if you connect this, pls be careful,your TV voice level will drive the stereo volume....
Hope this helps!..if more help requires Would you please let me know the result ?
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for us
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
Car stereo cuts out
It is possible a self-protect feature may be shutting down output. Check all of your wiring, following the manufacturer's instructions exactly. Faulty wiring is a major cause of poofed audio output devices in car audio. Any short in wiring, or an open (intermittent or otherwise) can cause a problem here. Internally, bad solder connections where the output devices solder to the board could cause problems too.
Jul 03, 2007 | iLO XM-MP3-CD Car Stereo
Model no. dtq2605fc how do we hook up a dvd player to this?
There are several ways to hook up a DVD player to a TV.
The simplest method, which works with any TV, is to use the DVD player's RF (radio frequency) output on channel 3 or 4, connect the output cable to the TV's antenna jack, and put the TV on the appropriate channel. There are two problems with this method, though. First, I'm not aware of any new players that have RF output these days. The manufacturers don't include it, figuring you'll be using the direct audio and video outputs. So if you're trying to connect a new player, you likely don't have this option. Second, if the player does have RF out, it's usually not stereo sound and the picture quality can suffer.
If the set has AV input jacks available, you would use those and select the AV input from the remote control or front panel. There are some possible problems with this method too. The biggest one is that if you've lost or thrown away the original remote, you might not be able to select the AV input. (Don't laugh, many people don't realize they should keep the original remote even if they never use it.) And on TV sets with only mono sound, you need a Y-adapter cable to combine the right and left audio outputs into one channel, so you lose any stereo effects.
The last way is for TVs without an AV input and DVD players without RF output. You use an RF converter (also called an RF modulator), which takes the audio and video signals from the player and makes a channel 3 or 4 signal you can tune in as I described earlier. RF converters are available at Radio Shack stores, most TV retailers and from many sources online. They're easy to connect, but you'll need an AC outlet nearby since they need power.
One of these methods will work for you, and you'll be watching DVDs soon. Thanks for using Fixya!
Apr 05, 2011 | Daewoo DTQ-13V1FC TV
I lost the manual to connect, so i need know how can i connect this with the LCD screen & autostereo/ Thanks
Please Check your AV ( audio cideo ) output of DVD. Standard Audio has two wires ( color red and white) Standard video has 1 wire ( color yellow). Just connect them to AV IN of your TV . Please paired the colors .
Jan 24, 2011 | XO Vision XO1510 Car DVD Player
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Jan 01, 2011 | Hitachi C21-F200 21" TV
Can u explain how to set up the television system with my digital television box.
The digital box should have a round threaded output connector on its back panel. These are usually marked "OUT TO TV" or "RF OUT" or something similar. There may also be a slide switch nearby to select channel 3 or 4 output to the TV. On some boxes the output channel selection is through and on-screen menu. You only need to connect the output of the digital box to the TV's antenna connector, then tune the TV to channel 3 or 4 depending on the box setting. Leave the TV on that channel all the time and do your channel changing on your digital box using its remote control.
If your TV has an AV input for connecting a device like a VCR or DVD player, you can probably connect the digital box that way. Most boxes provide stereo audio and video outputs, and you will get a clearer picture and sound if your TV has the input jacks. If your TV is not stereo and has just a single white input jack for audio (instead of red and white ones for stereo right and left), you'll need a Y-adapter to join the audio outputs from the box together to feed into the TV.
On the off chance you have a digital box with no RF output (I've never seen one since they need to work with older TV sets, but I don't know evey model), and your TV doesn't have AV inputs, you need an RF converter. The converter takes the audio and video signals from the digital box and generates the channel 3 or 4 TV signal that your set can pick up with its tuner. You can find RF converters at larger retailers and online.
Dec 12, 2010 | Disney 13" TV
How do we connect he console to the tv, or what output does the tv have to be on?..we lost the instructions
The console connects to the red, white, and yellow av plugs located usually at the back, sometimes on the side, of your tv. Typically this will be linked with channel 4, but could also be another av selection depending on your tv.
Jan 01, 2010 | LeapFrog Clickstart My First Computer
LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
May 25, 2009 | Rio Go Video DDV9475 Dual Deck VCR
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Nov 25, 2007 | Car Audio & Video
Metra Line Output Converter Logo
24 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
