Question about D-Link DGL-4500 Wireless Router
Trying to reset our security code on our DI624 router, but it is asking for username and password,,, have tried resetting the router to factor default but still asks for username and password. which unfortunately I have forgotten
  • 1 more comment
  • nancie1186 Jul 11, 2010
    Are you holding the reset long enough 30 seconds? If so it must be looking for the default user name and password user try: admin password: password you can also try logging in with: username: user password: (leave this blank)
  • Wendy Turner
    Wendy Turner Jul 12, 2010
    i have tried using admin for the username and password blank. I have also tried resetting the router but it still asks for a Username and a Password
  • nancie1186 Jul 12, 2010
    Have you tried Admin as the user and the password field entering password? Or user as user name and password field blank?
    President:
  • 1,118 Answers
Log in to your router's web administration application by entering 'admin' as 'User name', and leaving the 'Password' field empty.
Hope it works for you.
By the way, if your router's user manual happens to be missing, feel free to download it from this location.
Best regards, Carlos
Posted on Jul 11, 2010
  • CARLOS R SOUZA JR
    CARLOS R SOUZA JR Jul 12, 2010
    Only now I realized that your router is, in fact, DI-624, not DGL-4500. Anyway, according to its user manual, which you can find here, if you use a paper clip to press the reset pin (at the back of the router) for some 10 seconds, it should reset to its factory defaults. After its initialization, the 'admin' as 'User name' and 'Password' field empty combination should work.
Can't login to Netgear WNR3500L router
try 192.168.1.1
if that don't work try to reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
password is password
Jan 30, 2012 | NetGear WNR3500 Router
Linksys password recovery
Computer Hope does not assist users in bypassing this security measure. If this is your router and you've forgotten the username or password we suggest that the router be hard reset and then setup with a new username and password.
Default username and password
Before doing a hard reset on the router you may want to try the default username and password. While this is not the same for all routers, this may allow you access to your router.
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com.
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Dec 21, 2011 | Linksys Wireless-G WRT54G Router
I am trying to reset my netgear wireless wgr614 router. i am pressing the button in the whole for 15seconds plus. there after i am connecting the lan cable to the router and entering the basics settings...
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 23, 2011 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Forgot the password i tried so many times but incorrect allthe times
You will want to try
username: admin
password: admin
username: admin
password: 1234
username: admin
password: password
If these dont work you will want to reset the router back to defaults.
Mar 01, 2011 | NetGear WGR614 Wireless Router
Where can I find my DI-524 Username and Password?
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Jan 03, 2011 | D-Link AirPlus DI-524 Wireless Router
I cannot gt into the router
Hard reset properly for 30 secs. & Powercycle and try again.
Mar 17, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
When I enter "http://192.168.0.1" it's asking me username and pas
hi
for the username use administrator and ofcourse the password that u have set
cheers
pls rate if it was any help
Jul 07, 2009 | Levelone CP TECHNOLOGIES LEVELONE...
Locked out of wireless router .
On the rear of the router is a recessed reset button. You'll need something like a pen point or a straightened paperclip to press it. Turn off the router (pull out the AC adapter plug), the plug it back in while pressing the reset button. After the lights on the router quit blinking, let go of the button. This will reset the router to factory settings. When you go to //192.168.1.1 and are prompted for username and password, the username is blank and the password is admin. (It's possible the username may be admin and the password is password. This was in some versions of the router.) Then you can set your router up again the way you want.
May 18, 2009 | Linksys Wireless-G WRT54G Router
Second computer
  • The router username is always admin
  • The default password is password or (for older routers) 1234
Try the default username and password before resetting the router to the factory defaults.
When a router resets, it goes back to the state when it was new — all information that was entered by hand is lost! Examples are critical things you need to get online, such as ISP username, ISP password, IP addresses, security keys, and ports and services that were opened. It all needs to be re-entered.
Oct 09, 2008 | NetGear WGR614 Wireless Router
I cannot find the security code for my Linksys system. Is there a way of retrieving it? I noticed that at certain hours of the day - especially at night, the added computer laptop functions with...
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
Logging in to a LinkSys Router
LinkSys Default Password On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router.
Jul 17, 2008 | Computers & Internet
D-Link DGL-4500 Wireless Router Logo
242 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
