Question about HP OfficeJet 4315 All-In-One InkJet Printer
I continue to get "Cartridge Error" messages. I have cleaned the contacts where the cartridge seats in the device, and I have used a number of different cartridges in an effort to rule out bad cartridges as the problem. Is there anything else I can do? If the color cartridge is the problem, how can I make that determination without buying another color cartridge?
    President:
  • 1,194 Answers
Hi Rtpinina,
Thanks for using Fixya.
As you have stated that you have cleaned the contacts f the printer and cartridges, therefore, Perform a hard reset on the printer
  • Verify that the unit is turned on.
  • Remove the power cable from the back of the printer.
  • Wait 30 seconds.
  • Press and hold the POWER button on the front panel.
  • Plug the power cord in to the back of the printer.
  • Print a test page. If the problem persists, replace the cartridge.
Also check from this Link that the ink cartridges being used by you are compatible with Officejet 4315 or not.
Check if you have removed the protective tape from the cartridge or not.
If the problem is still there, then print cartridge or sensor is defective.
Good luck and have a nice day.
Posted on Jul 11, 2010
  • 2 more comments
  • rtpinina Jul 11, 2010
    When I hold the power button down and plug the power cord back in, the unit does not turn on. I am forced to release the power button, then press it again to power up the unit. When I do this, I immediatley receive a Cartidge Error message. Should I be keeping the power button depressed while pluggin in the power cord, or should I release it after 30 seconds then plu in power cord.
  • Ranglo
    Ranglo Jul 11, 2010
    You are supposed to plug the power cord while pressing the power button......
    Still not correcting the problem. Any other options? How about uninstall/re-install the software?
  • Ranglo
    Ranglo Jul 11, 2010
    You can try this also...but i don't think it's a software problem.
    The problem is either with the cartridge or with the sensor.
Cartridge error 1203
The 1203 error indicates either a communication failure between one of your cartridges and your printer or a short in one of the cartridges. Please follow the steps below to fix the problem:
1. Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3. Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5. Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7. Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
1. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2. Remove the cartridges. Clean the cartridge contacts (How to Clean the Print Cartridge Nozzles and Contacts Manually).
Source: 1203 Error Message on the Lexmark X7170 All-In-One
Oct 08, 2011 | Lexmark X7170 All-In-One InkJet Printer
I cannot copy or scan message #1203 keeps coming up
The 1203 error message indicates either a communication problem between one of your cartridges and the printer or a short in one of the cartridges. Follow the steps below to fix the problem:
  1. Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on. Did the error message return? Yes: Continue to step 2. No: Print a test page. If the test page prints, the error is resolved.
  3. Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on. Did the error message return? Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark. No: Continue to Step 4.
  5. Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return? Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test. No: Continue to step 6.
  7. Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on. Did the error message return? Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test. No: Print a test page. If the test page prints, the error is resolved.
Source: 1203 Error Message on the Lexmark 4200 Series All-In-One
Jun 23, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have a Lexmark P4350, I put a new 33 color ink cartidge in and it does not reconize it and has an Error 1102
The 1102 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In-One (AIO).
The procedures in this article will help you to resolve this issue.
Troubleshooting a Communication Error between the Cartridge and the Printer
Please follow the steps given below:
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO back on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark below.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power on the AIO.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action
1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges and clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions).
Defective Cartridge Check
To test the cartridge, replace it with either a new cartridge or a known good cartridge from another printer of this type. If the error message persists, proceed to Contacting Lexmark.
Apr 03, 2009 | Office Equipment & Supplies
I have error #1203 on screen
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO) or by a short in one of the printheads. The procedures below will help you to resolve this issue.
Step Action:
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Step Action:
2 Remove the cartridges. Clean the cartridge contacts and the AIO carrier contacts
Apr 03, 2009 | Lexmark X4270 All-In-One InkJet Printer
Message says cartridge error 1203 and it wont
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
Feb 23, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Cartridge Error Message
Feb 16, 2009 | Lexmark X7170 All-In-One InkJet Printer
Error 1203 Lexmark F4270
The 1203 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. The procedures in this article will help you to resolve this issue.
Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
Dec 16, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Mar 27, 2008 | HP Officejet 4355 All-In-One InkJet...
Error message 1102 when i put cartridge # 33 back in
Overview
Step Action
5
7
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
Mar 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
Hp 4355 cartridge error
Mar 10, 2008 | HP Officejet 4355 All-In-One InkJet...
HP OfficeJet 4315 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
