Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
My dishwasher smells
There is a terrible smell from my dishwasher when not in use it is a built in dishwasher
  • Bosch Expert
  • 414 Answers
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removed) this will expose the pump impellor and you can check for any obstruction.
Try running a 65 degree wash with a couple of caps of baby sterilising fluid. If the d/w is connected directly to the sink, remove the spigot and check there aren't any blockages. I run a dishwasher cleaner thru my d/w every 3 months and every couple of week I will load the machine for a wash, add tab to dispenser and just after starting a 65 degree wash, I will open the door and tip in approx one capful of sterilising fluid.
baby fluid is also good as a sluice wash for your washing machine on 90 degrees (w/m empty, approx every 4 weeks). https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S
ps I appreciate the link is not for your model but the part placing should be the same.
I hope this helps, Good Luck.
Posted on Jul 12, 2010
3 Suggested Answers
  • 7 Answers
SOURCE: Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Posted on Aug 11, 2009
Daniel S
  • 4323 Answers
SOURCE: Terrible smell inside the dishwasher.
Hi
The smell usually comes when the unit is unable to drain water completely, you can run your dishwasher at its hottest temperature setting with 2 cups of vinegar inside the unit. After this take off the lower front panel and clean the drain pump assembly completely, also clean the drain hose, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 06, 2011
Terrible smell inside the dishwasher. Bad drain smell
Hi
Daniel
Aug 05, 2011 | Dishwashers
Terrible smell from the washer. This is a new
do not use baking soda this will react with your detergent and leave smelly deposits and reduce the wash performance modern good quality detergents contain everything needed for a good wash result and a sweet smelling machine. try a hot wash with detergent and an empty load to get rid of smell.
Nov 07, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Maytag Quiet Series 300 smells broken door latch and lower rack
I have had the same problem and there is a simple fix.
The problem in my case was the floating water sensor was stuck and gummed up with grease.
On the bottom of the dishwasher, in the front right corner there is a round doughnut-looking thing. This is the water level sensor. It is open on the bottom, and grease collects there.
When this happens, the air pocket is too small, and the float won't float. then the dishwasher overflows. To clean it: just reach under with your finger, and scoop out the grease.
Sometimes, after doing this, the float then gets stuck in the "up" position. When this happens, the dishwasher completely drains, and the heater element for the dishwasher is exposed, and food cooks onto it, and that is where the smell is coming from.
Sep 05, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwasher smells has a 'wet dog' smell
its the food and the steam together. its normal.
Aug 23, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher has terrible smell and water lays inside tub.
The drain is plugged. You will have to pull out the dishwasher and clean out the drain port. A repair person could also do this for the price of a house call. The smell is coming from the dirty water in the tub. You'll have to bail this out before making the repair.
Jun 29, 2009 | Maytag MDB9600A Jetclean II Built-in...
There is a terrible smell in the dishwasher
All DW that I know of will have water sitting at the bottom.. it keeps the seal moist..check your drain line make sure its clean and not clog... when your DW goes into drain listen to see if its drainning like it did when you first used it... I'll check back later..
Jul 20, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Terrible smell
yea disposers are most likely cause of odores backin up into the d/w's you can try running through a cycle with a bowl full of vinegar. the vinegar will flush put of the bowl during wash and get all the nooks and crannies clean
Apr 16, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
233 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
