Question about Dell Inspiron 1525 Laptop
I want to hook up my laptop to my tv but i dont see where to hook it up on my tv
    President:
  • 2,571 Answers
It all depends what outputs you have on your laptop, and what inputs on the tv.
If your TV is a modern lcd or plasma type then you have a couple of options.
You may have to use a vga cable like this 1 http://www.annoyances.org/exec/forum/winxp/t1034931646
This transfers video only
If you have a HDMI socket on your laptop and tv then this is the best way. Plus it transfers sound also.
Posted on Jul 11, 2010
Laptop to tv hook up
most modern tvs have vga connector for doing just that look at the back of the tv should be one there. If not then look for what is called a Svideo socket will be a small circle plug with about 5 pins and dont forget to put the tv mode to its respective setting ie P.C or Svideo/ AV1
Jan 06, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How and what do I need to hook up my laptop to the tv
You have many options but probably the easiest is to use an S-VIDEO cable.
If your laptop has HDMI you could also use that method but the cables do tend to cost a little more (worth it though for quality picture)
If you TV has a VGA connector then that is probably the cheapest and quickest way to get a quality picture.
If your laptop came with an S-video to composite (phono) type adapter you can also use that but the picture quality is not as good.
Your TV has DVI and S-video so one of those would be a good bet. dont cheap out on the cables though !
In my experience many cheap S-video cables are useless when it comes to hooking up computers to a TV
Aug 09, 2009 | Mitsubishi WS-65413 65" Rear Projection...
HP Laptop to TV
You cannot connect VGA OUT to component IN on your TV without using a converter. However, You can connect VGA OUT from your laptop to VGA in on your TV using a VGA cable just as long as your TV has VGA in. You will need to hold the FUNCTION or FN key on your laptop while press the F4 or F10, whichever F key has the picture of the monitor on it. This will switch your laptop from LCD to external display or both.
May 02, 2009 | HP Televison & Video
How to hook up a hp pavilion laptop to a hdtv
if it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Jan 16, 2009 | HP Pavilion dv6000z Notebook
Is there someway to hook up our Hitachi 42HDS69 to our laptop
Your computer should have a DVI port to make this possible since your TV dont have a VGA port. If your computer have a DVI port then an HDMI/DVI cable is all you need. This allows you to connect you computer or laptop to you tv through the HDMI connection on your tv.
Dec 31, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Lcd hdtv is hooked up to laptop but it is every 10 sec gos black
if theres nothing happening on ur pc like same as tv its probably the tv config ...
check tv setup
check tv screen saver..if it disabled it would explain why screen black...
could try checking power settings in pc(screensaver properties)
Dec 10, 2008 | HP Compaq Presario V6000T Notebook
Wireless internet and tuner
You need to have a tv tuner to be able to watch tv. If the express card you have is a tv tuner, you'll have to run a cable from the laptop to your cable tv connection or set top box. You can't do it over the internet.
Nov 02, 2008 | HP Expresscard TV Tuner For Windows Vista...
S-video dont work on latitude c600
there is a needed interface for the tv. the video signal your laptop generates is not compatible with the input circuits of the tv.
Dec 27, 2007 | Dell Latitude C600 Notebook
Dell Inspiron 1525 Laptop Logo
125 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
