Question about Symphonic WF803 DVD Player/VCR
No remote i am not sure if i can operate this unit without a remote. can you help and if needed where can i get a remote
  • 171 Answers
Hi! you need universal remote control. i am sure it can control everything that comes with a remote. you can buy it in computer shops, or shops explicit for technic. it costs around 15$.
Posted on Jul 11, 2010
How to hard reset unit without remote
  • Reset the unit to factory default settings as follows:
  1. Press [POWER] on the unit to turn off the unit.
  2. Press and hold [FAST FORWARD] and press [POWER] and [OPEN/CLOSE] on the unit at the same time for more than 5 seconds until "PLEASE WAIT" is displayed on the unit.
  3. The power is turned on and then turned off automatically.
http://service.us.panasonic.com/OPERMANPDF/SCBT200.PDF
Feb 18, 2014 | Panasonic Audio Players & Recorders
Operating a panasonic dmr-ez47v without a remote control
Many DVD recorders need the remote for a few functions like menu and setup. The remote part # is EUR7659T80 in the US. You can order parts here . it costs about $35 US. Save yourself some headaches.
Feb 21, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
The buttons on my air conditioner quit working. It will still turn on and off. It is now set to fan. Will a universal remote work with it? I don't want to spend $75 on a remote(replacement remote) that...
I'm not sure there is a universal remote available for AC units. There may be, I just have not seen one. However, you can still operate the unit without the remote, if you do the following. I'm assuming you have changed the batteries in the remote and they were installed properly (i.e. Facing the right direction) and it still doesn't work or you lost the remote.
Turn the unit OFF and unplug it for 15 minutes. Once the time has elapsed, plug the unit back in and turn the ON/OFF switch to ON. The unit should have reverted back to the original factory setup settings. Which should now allow you to operate the unit without the remote, because the controls on the unit should now be activated.
I hope this helped you and thanks for choosing FixYa.
Aug 07, 2011 | Frigidaire FAM156R1A Wall/Window Air...
Unit will not turn on without the remote.
To operate the unit without having the remote .. Turn the unit OFF and unplug it for 15 minutes. After the time has elapsed, plug the unit in and turn the ON/OFF Switch to ON. You should now be able to operate the controls on the unit itself. As it should have reverted back to the original factory setup settings.
Hope this helps you and thanks for choosing FixYa.
Aug 07, 2011 | Amana ACD105R 10000 BTU REMOTE/TOUCH ROOM...
My unit requires remote control to operate remote control is lost what 2 do
Whether you have a thru the window model or a potable AC, the same controls that are on the remote are on the face of the unit. To operate it without the remote, turn the unit OFF and unplug it. Wait 5 minutes, then plug it back in. Wait 3 minutes & turn the unit ON using the controls on the front of the unit.. The controls will have reverted back to the original factory settings and you can now use the front control panel to operate & set the controls as you like.
If you want to purchase a new hand held remote, contact Haier Product Support 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 02, 2011 | Haier Heating & Cooling
Can you operate an amcoraire duo UCHW-H12AF2 without a remote control?
The unit will run @ 75 degrees without the remote. Go to Ebay.com
Search Amcoraire Remote Control, you will find what you need.
Jun 24, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
Reiker ceiling fan - does not turn on - theres is power to unit - maybe remmote is bad? how do i change code
Before trying to change the code, have you tried changing the batteries? Both in the hand held remote and the one in fan housing? If so, and that didn't help, make sure the batteries are turned in the right direction and fitting tightly.
Will the fan operate without using the remote control?
Feb 19, 2011 | Reiker Room Conditioner Heater
LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Jun 24, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Is there an input select?
I can view channels but cannot view a DVD from the TV/DVD Disney Princess Combo. Only see static on the screen with no sound. I wonder if I need to change the input select to view a movie but cannot find a button on the TV or remote control. I have a 6 button remote which I am sure operates the DVD and another remote with 39 buttons I thought would operate the player as well as the TV. However, so far only the player functions from it. The buttons only have small pictures without words which sometimes leaves some question about purpose. This is a second hand unit. I do not have a manual. It did play movies at first. I think the trouble may have started when I programed cable channels. Any help will be greatly appreciated
Apr 24, 2008 | Disney DT1300-P 13" TV
Open Questions:
Symphonic WF803 DVD Player/VCR Logo
73 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
