Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
42EDT41A Blinking LED on Main Control Board
I have an 42EDT41A with great sound but no picture. I took the back cover off and I noticed that the Main Control Board in the bottom of the 42EDT41A had an LED that constantly blinked to indicate a problem. Since I don't have the service manual for the 42EDT41A. I was wondering if you guys could help me diagnose the possible cause. I do know from researching your site that the 42EDT41A has a PCB problem, but no one has yet to state which PCB it could be.
  • 2 more comments
  • Anonymous May 27, 2008
    ver lines
  • Anonymous Sep 10, 2008
    I have exact same problem. Good sound, no pic.We ordered the signal board, along with the main power supply board(in center of set). The signal board we ordered had the wrong plug on it where the tuner plugs into it, so we couldn't try it. The main power board had no effect on the problem. We're going to try to get the correct signal board and try it.
  • Angharad1 Sep 13, 2008
    Same problem with no picture. Specifically about the LED lights : D13 is lit D17 steady flashing. Any help appreciated. Where are you purchasing parts for the TV. Also anyone know where a service manual is available?
  • Anonymous Jan 06, 2009
    my tv does the same thing, sounds fine but no picture...what happens, however, is that the picture slowly comes up but after hours. Any idea what i should do?
SOURCE: Hitachi 42EDT41A
Try replacing signal board
Posted on Feb 25, 2007
SOURCE: Blinking lamp LED after lamp replacement
OK I fixed mine. I took out the new bulb, and on the back side, there is a little tab on the right side of the lamp that should depress the safety switch. I think that once you take out the original bulb, the switch lever is weak and once you replace the lamp, the new one cannot depress the switch far enough. I built up under the tab (with some plastic from a pen pocket clip and some super glue)(after I took off the back of the tv to see what was going on) and it depressed the switch farther. I put it back together, and now it works. Saved a few hundred bucks. Good luck...
Posted on Nov 30, 2007
likha
  • 790 Answers
SOURCE: Hitachi 42hds69 blinks 8 times and powers off and powers on, cycle repeats
Hi try this links. click here
thanks!
Posted on Jul 31, 2008
  • 362 Answers
SOURCE: hitachi 42edt41a no picture help
Bad buffer board, Let me know if I can help. lone99star
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: No Picture or Sound, Blinking blue light
the bulb is blown, replace bulb prie 150.0 to 250.00 it is not a hard repaitr to do yourself.
Posted on Jun 09, 2009
LG LED TV 55LN5600. Backlight goes off after maybe 30 minutes. The sound is on. picture is on (tested with flash light). Replacing power supply board did not fix the issue.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 04, 2017 | LG Televison & Video
I have a samsung tv with a dark screen
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 29, 2017 | Samsung Televison & Video
LED TV no picture, but sound. Did flashlight test and determined backlight is the problem. Power supply/inverter or bad LED?
Jun 17, 2016 | Westinghouse Televison & Video
LG 60 inch LED smart tv has no picture or sound and blinking power led light. What could be the cause of the problem?
you might want to look at chips on y sus board for small holes in them common on lg tvs
Jun 25, 2015 | LG Televison & Video
LG 42PC!R Plasma TV turns on and then green led blinking with no ppicture and sound !
Your problem is most likely a fried circuit board. I always connect my good electronic to a back up battery. but your problem might have been storm or surge related, I would take it to a repair center and get an estimate.
Sep 19, 2014 | LG 42PC1R 42 in. Plasma HDTV
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
TV comes on and Volume works but no Vison.
From what i can gather from your inquiry it is going to be the Logic Main, that is if you can see a constant blinking LED on the board and a constant on LED right next to it.
Feb 24, 2010 | Sanyo DP42746 42 in. Plasma Television
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42PF9630A 42 in. Plasma 42 in. Plasma
Ok 7 red blinking led, remove the back cover of the TV. Looking at the power supply in the upper left of power supply. If everything is working fine you will see a solid green led if there is an error, you will see this light blinking also. Right below this led on the power board you will see a list of numbers 1-13 this will give u the problems that this led flashing problems are. More and likely u will have a problem with VSET or VSCAN. Which is connected to the Y-Main and Y-buffers,( the board that is too the left of the power supply if u look on the small print on this board you will see that it reads. 42HDV4 Ymain and the 2 small boards connected to it are Y buffers. To be sure that this board is bad if the TV keeps going into error protection. unplug the power supply and wait for the led to stop flashing. Disconnect the cable that plugs into Y-Main from the Power Supply. It should stay running. If u remove this board and look underneath u should be able to see where this board is getting hot. Easiest fix is to order a replacement. Y-main assembly.
May 05, 2008 | Televison & Video
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
187 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
