Question about Dometic Refrigerators
We have a 2510 Dometic Refrigerator that won't chill in either gas or 110. Could it be the thermastat?
  • mean_oleman Jul 11, 2010
    I did not get an answer from the last question. I was under the impression that we were online
  • 6,993 Answers
yes, its possible, but don't over look other areas that could be the cause of the problem.
You can follow the troubleshooting steps below as you might get to the root of the problem:
  1. Check that the temperature control knob isn't in the "off" position.
  2. Move the temperature control knob to a colder temperature setting.
  3. Check that the fridge isn't unplugged or that the fuse or circuit breaker isn't blown. Reset the circuit breaker or replace the fuse as needed.
  4. Make sure the red defrost button hasn't been inadvertently pushed. If the button is pressed the fridge will run through its defrost cycle. You can't turn the cycle off until it has completed. Part of the defrosting function includes warmer temperatures
  5. Determine if the ambient temperature has become hotter. For example, is the weather warmer than when you initially set the fridge temperature, or is the air conditioning set higher? If so, set the temperature control one step colder.
  6. Determine whether you are opening the fridge door more often than usual, or if a food package is keeping the door open. Remove any obstructions.
  7. Make sure the door seal isn't dirty and preventing the tight contact required. Wipe the seal on both the door and the body using a soft cloth and warm water.
  8. Make sure the fridge hasn't been built-in or placed in a too tightly confined space. If it is, the hot wall condenser won't work properly. Test this by pulling the fridge out into the room to see if the temperature stabilizes.
Good luck.
Posted on Jul 11, 2010
  • 1,284 Answers
Hi, if that be case check the thermostat as you have suggested and you can also check the relay starter which is situated near the compressor.
Take care
    We are looking at the manual, is there a way we can send you a scanned copy because we have no idea where this would be. The items described are as follows:
    1. Plug
    2. Thermo Electric Safety Valve
    3. Thermo Couple element
    4. Coupling
    7. Thermostate
    9. Cut-off valve
    10 Nipple
    11 Nut
    14 Switch
    23 Reigniter
    26 Burner
    27 Electrod
    29 Terminal Block
    30 Sealing Ring
    31 Snap Catch
    33 Burner Houring
    36 Terminal Block
    38 Burner Jet
    43 Cover
    46 Cover
    47 Flue Baffle
    50 Heater
    51 Bushing
    52 Clamping Plate
    53 Flue Top
    55 Label for 12V
    57 Burner retainer
    59 push Rod
    60 Shaft, thermastat
    61, shaft, switch
    62. Lead for 12/120v
    64 Fleixble Cord
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
NDR 1062 Dometic Refrigerator
Not unless you unplug the thermistor from the circuit board and let it run for 24 hours. If it does not cool after that then your cooling unit is bad.
Dec 05, 2013 | Dometic NDR 1062 Refrigerator
My Dometic NDR1062 only runs on gas, its set for auto and has 110
There is a control board and a step down transformer that may be at fault.
These should be located in the lower rear of the unit.
Jul 11, 2010 | Dometic NDR 1062 Refrigerator
Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Oct 23, 2009 | Dometic RM2652 Refrigerator
Dometic rm 2620 fridge problem
The flame is not hot enough check gas pressure
Jun 22, 2009 | Dometic RM2620 Refrigerator
Is there a 12volt coil in a Dometic rm52 refrigator
What you would need to do is get an inverter to power the icebox. Turn the 12 volts into 110 to power up the compressor. THE INVERTER STORE has aone for $199
May 16, 2009 | Dometic RM2652 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
212 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
