Question about RCA F36650 36" TV
RCA Model # F36650 tuner.
I would like to know what kind of tuner this model has SDTV, ATSC or do I need a digital converter box? Thank you.
  • Anonymous Mar 29, 2014
    digital tuner
If you're asking just for the purposes of the new Digital era that is coming, then YES, you will need a converter box. If the TV is hooked up to cable, then you can do without the box. If you go to they have a section on their site that let's you put your model number in to see if it will be ready for the new digital that is coming. Hope this helps!
Posted on Oct 12, 2008
If your tuner is already dead replace it.because the original tuner of your TV is very expensive. the solution of your TV is converting tuner, you buy a kit name AUDIO TV CONVERTER . simply conection and and not very expensive. just plug the unit to ac line and connect the cable line to rf of your Television and its OK. im just trying to suggest my solution to you JRANDY phillipines tech
Posted on Apr 19, 2008
It depends on the model and the source. The DRC212N is not a recorder, so it won't.
Depending on the model, it may or may not have a tuner. (Most modern ones are sold without any tuner. Older models may only have an analog (NTSC) tuner.) I know of one Magnovox DVR/DVD recorder that has an ATSC (digital) tuner.
If you are going to record OTA signals, you will probably need a digital to analog converter. If you are recording from a cable or satellite system set-top box, you need to set the channel on the box and then record on Line In. (Analog cable should record directly.)
Please add a comment with more information about your DVD recorder. I'll be glad to provide more assistance. I hope this helps.
Feb 03, 2013 | RCA DRC212N DVD Player
Would like to know if my toshiba model 20AF46 will need a converter box fo receive digital signal?
Yes you will need a converter box. This television does not have a digital tuner. It does not have an atsc tuner. It does not have a qam tuner.
Sep 14, 2011 | Toshiba MD13M1 13 in. TV/DVD Combo
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
I don't know how a program it, since you change digital.
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
I am not using cable or dish...what type of antenna should i use to get the most out of the digital conversion...and is the built in converter adequate or do i need converter box?
The specs for this TV shows it has ASTC and NTSC so you do not need a converter box.
Almost all the Digital channels are broadcasted in the UHF band.
When you scan in the channels the VHF numbers will still show but the actually signal will be in the UHF band.
Go to
WWW.TVFOOL.COM and enter your ZIPCODE to get the stations in your area.
MPN: IWT3206 Key Features Digital TV Standard: SDTV Diagonal Screen Size: 32 inch Display Capabilities Built-in Tuner: ATSC · NTSC Image Quality Comb Filter: 3DYC / 3D Digital Audio Features Audio Type: Stereo SAP / MTS Stereo: SAP / MTS Stereo Technical Features Sleep Timer: With Sleep Timer Connectors Rear Input Connectors: Composite x 1 · Audio (RCA) x 1 Front Input Connectors: Composite x 1 · Audio (RCA) x 1 Screen Text OSD Languages: English · French · Spanish Miscellaneous Product ID: 37594421 More Information Details: Big picture, small price. Enjoy watching your favorite, sports, programs and movies on this generously-sized 32" TV from ilo. The side stereo speakers help create a richer sound experience. Even more conveniently, the built-in digital (ATSC) tuner accesses digital content without the need for a separate set top box that takes up space. And since the screen delivers standard definition (SD) resolution.
Apr 05, 2009 | iLO IWT3206 TV
Is my sansui sdtv 3200A dtv ready?
SDTV The "D" means 'Defenition' not Digital, S is for 480i. You will need a convertor box. Sorry.....
Feb 16, 2009 | Sansui DTV3200 32" TV
Programming a ATSC DTV tuner on a RCA Universal Remote
Try a code for a "satellite receiver" of the same manufacturer of your DTV tuner. I've heard of a cross-remote complaint with the DirectTV box and the DTVPal box. Note, your DTV tuner may say RCA, but it could be manufactured by a common DTV tuner maker. The system looks very close to a Zinwell. Don't have an RCA model to try the codes out, though.
Dec 27, 2008 | Televison & Video
I want to know if my tv is digital ready.It is a ilo tv with a sdtv tuner,mts stereo.dolby digital,ccd. Will i have to buy a digital converter
SDTV does not mean hi def but it does often mean digital. dont know what model you have but if it can tune ATSC or the channels with the dot, like 10.1 or 8.3 then your good to go.
Aug 26, 2008 | Televison & Video
RCA Television Model 20F420T
their are no hd crt monitors that I am aware of, your tv as per the descriptions I find says nothing about an atsc tuner therefor I would say if you do not have cable or satellite receivers you will need a converter box to receive hd signal from your current antenna
May 10, 2008 | Televison & Video
Do i need a didgital converter for my SDTV model #27F634T or does it have the digital tuner already and I can use an antennae to receive analog or digital signals?
Greetings mockus5,
If your unit is the RCA 24F634T, then yes, it does already have a digital tuner and is capable of using an antennae to receive digital and analog signals. No converter box would be needed.
Thank you,
Go Ahead. Use Us.
May 01, 2008 | Televison & Video
RCA F36650 36" TV Logo
130 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
