Question about Dyson DC14 Full Gear Bagless Upright Cyclonic Vacuum
Dyson runs about 5 min then shuts off
Problem with my dyson dyson runs for about 5 min than just shuts off . If you wait alittle it will run again, but shortly aftyer stops>
  • 74 Answers
REMOVE AND CLEAN FILTERS AND YOU MAY FIND IT WILL WORK OK IF STILL CUTS OUT YOU MAY HAVE A FAULTY THERMAL CUT OUT BLOCK INSIDE THE MOTOR HOUSING
THIS HAPENS WHEN DYSON IS USED WITH CLOGGED FILTERS AND HEAT DAMAGE TO THERMAL BLOCK
AVERAGE REPAIR COST £45 - £ 69 FOR NEW REPLACEMENT
Posted on Aug 25, 2010
  • Bob Emery
    Bob Emery Apr 11, 2015
    I cleaned the filter. The DC72 now works perfectly. Thanks.
Eureka maxima heats up and shuts down after 10-15 minutes use??
sounds like you have a clog some where or need to replace your filters. your machine is tripping the thermal switch thats why it only runs for 15 min
Apr 02, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Swithes itself off after approximately 5 minutes?? is ready to use again approx 15 mins later but again only for 5 mins ? Angela
Sorry to hear you're having difficulties with your DC07. Like most Dyson cleaners, your DC07 is equipped with a safety device which shuts off the cleaner if it starts to overheat. This is often due to a blockage, or because the filters need a wash. The easiest way to check for and remove any blockages is to follow the steps shown in our online guide:
http://www.dyson.co.uk/support/help.asp?article=4&product=DC07-SY
The correct way to wash the filters is shown in the video embedded below. The filters should be washed in cold water at least once every 3-6 months. Always ensure they're totally dry before replacing them.
Hopefully this should resolve your issue. However, if you've followed these steps and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you and recommend the best course of action.
Kind regards,
Jack
Dyson Online Customer Support
Jun 17, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson animal shuts of after 5-10 min of use
The "hidden" filter at the base of the unit is the HEPA filter, there is another filter on the side of the vacuum that you can remove and wash with water. Make sure that is washed out. If it's too dirty it will restrict air flow and the motor will overheat.
May 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
After running for afew minutes it shuts off ??
filters plugged. possible unit plugged at floor inlet also.
May 06, 2010 | Dyson DC25 All Floors Bagless Upright...
My dco7 quits running after 10 min I wait 15 min to start again
This is a sure sign of a blockage. The motor cuts out because it gets too hot and will start again when it has cooled. Follow the instructions in your user manual for clearing blockages (you can download a copy from the Dyson website if necessary). Make sure the washable filter is clean too (and completely dry before you use it).
Jan 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I turn my dyson on and it runs for 5 min then turns off
The symptoms you describe are typical of overheating. That indicates that there's a blockage somewhere. Follow the instructions in your user manual for removing blockages (or you can download a copy from Dyson website if you need to), and make sure the filters are clean too. That should solve the problem.
Jan 07, 2010 | Vacuums
The motor may not be getting air flow past it due to clogging or dust build-up. It is probably shutting off because of a thermal overload switch. Good luck!
Jan 07, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
DC 17 UPRIGHT BRUSH MOTOR WONT STAY RUNNING. TURN
have a look at the filters first as it sounds like you blokeage
Oct 31, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have the same problem as steve967 The dyson dc16 is fully charged, runs well for 5-10 seconds and shuts down. I wait for a second or 2 and it runs again for 5-10 seconds. This will continue for...
Dear Michael_Stad,
I am going to sound like a broken record but here is my same answer to another person with the same problem.
I have I had the same problem with my Dyson DC16, where it only runs for a few seconds at a time with each trigger pull. My husband called Dyson (Canada) and without hassle they shipped us a replacement part which I just received this morning. The replacement part sent to us is: DC16 Main Body with Rating Plate. It is also under warranty for 1 year. The great customer service makes up for the flaw in the machine. Also, Dyson is aware of the problem. Hope this helps.
Oct 23, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Dyson dc07 animal
This is from the Dyson web page:
Get expert help Thermal cut out Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
Any non- domestic use may adversely affect the filter performance such as vacuuming up plaster dust.
Sounds like your vacuum is overheating. Check the above.
Lou
Aug 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 Full Gear Bagless Upright Cyclonic Vacuum Logo
898 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
