Question about Amana DRS2660B Side by Side Refrigerator
Water is dripping from the ice maker into the ice tray
  • 166 Answers
You may have a bad water valve. the valve could be not completely shutting off. when you hear the ice maker begin to cycle open the freezer door and watch it. look to see if the plastic tube coming thru the back of the refrigerator is not leaking after the ice maker has completed its cycle. if it is dripping and running over your water valve is bad.
you may also check the level of the ice maker. sometimes you can be out of level causing a slight leak.
Posted on Jul 12, 2010
  • 489 Answers
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Sounds like the water valve has a small leak and continuously drips water onto the icemaker.  Have the water valve checked and if necessary, replaced.
Posted on Apr 27, 2008
  • 210 Answers
SOURCE: Ice maker freezes up and drips water
I am assuming you have the ice maker that the tray twists to release the ice. There is a new tray out with a wall to prevent the water spilling over. The part number is
3390JA1150A
Sgt 48
Posted on Jun 03, 2008
  • 42 Answers
SOURCE: ice maker makes ice, but also drips water
cbscarter,
This may sound strange but you will find that the mold coating is peeling off of the aluminum mold. This causes the water to wick (climb) the loose coating and up over the top, leaking out making an ice clump on the ice maker and clumps ice in the container together. It would be easy enough for the average person to replace the ice make. Due to its age that would be smarter to replace than to repair the old one. It is a Whirlpool part #4317943 and comes with some instructions.
If this helped please rate me good, supertechks
Posted on Nov 25, 2008
  • 56 Answers
SOURCE: Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Posted on Jun 13, 2009
  • 1218 Answers
SOURCE: My subzero 650 ice maker drips water w/o making ice
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Posted on Dec 24, 2009
Testimonial: "If this works, it makes for a wonderful Christmas present. thsnks!!"
Why is my Uline ice maker filling with water not ice ?
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
Jun 04, 2014 | U-Line ULN Marine Series 12-lb Crescent...
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
Mar 31, 2011 | Refrigerators
The Ice maker does not make cubes.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Feb 06, 2010 | Refrigerators
Ice maker drips water into ice tray
Probably the solenoid valve leaks(electric valve that opens when the ice maker calls for water) and overflood the ice maker,the only way to fix this is replacing the solenoid.
Sep 22, 2009 | Kenmore Refrigerators
Water on the ice maker doesn't shut off - drips into the ice pan
Most models of Ice makers have an automatic timer for the amount of water that is allowed to enter the Ice Maker tray. If your timer valve is going bad you need to replace it. First I would reduce the amount of water coming from its source. There should be a tapped valve under your sink, connected to your water line. You have to turn the top of the valve clock wise to reduce the amount of water the is going to the back of your refrigerator. That is where you will find the timer valve. Reducing your water flow should help reduce the volume of water being let into your Ice Maker.
Jul 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Ice maker drip into ice bucket and manual cycle leaks more water
Need to take the ice maker out to measure the amount of water input into the ice tray. In this case the tray was already full (from the leaking valve). The spillage I saw was just the tray overflowing. Time for a new valve.
Apr 28, 2009 | Kenmore Refrigerators
Ice maker won't stop dripping
If your i/m is dripping you most likely have a crack in the ice mold, you should replace the ice maker.
Jan 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
3390JA1150A
Sgt 48
Mar 09, 2008 | LG LRSC26980 Refrigerator
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
Amana DRS2660B Side by Side Refrigerator Logo
154 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
