Question about Poulan Pro 22" Self Propelled High Wheel Mower
It starts up and sputters out in a few seconds . It has a briggs and stratton engine Used twice.
    President:
  • Poulan Master
  • 1,545 Answers
Remove the brass bolt holding the carburetor bowl on at bottom of carburetor. Inspect all holes and clean (at bottom and on smooth part of bolt). Clean out bowl also. Reassemble.
Posted on Jul 12, 2010
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
Have a Briggs and Stratten 4.0hp Lawnmower that starts but sputters. What can I do to get it running smooth...What is the Spark Plug GAP?
How old is the fuel? Drain old fuel, use premium fuel and change spark plug and maybe air filter. I start mine in the Spring using quickstart. It also starts and dies a few times and eventually keep running. Winterizing the machine in the Fall prevents most starting problems in the Spring. If this does not solve the problem, see a mechanic.
Jun 24, 2014 | Briggs & Stratton Briggs Stratton...
I have a brigg and statton mower 550 series its brand new i used it twice and now when i prime it it will start but run for a few seconds then stop what causes this can i fix it?
Hi bilsdrums53...
Sounds like you have debris/trash in your carburetor or maybe water in the fuel tank.
Check and clean your fuel tank.
Clean your carburetor and that should solve your problem
Aug 16, 2011 | Briggs & Stratton Garden
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Jun 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
225 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
