Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Amana Model SCD22TBW. Not getting cold. Not blowing any cold air. Changed the Temp control switch and the defrost timer and no luck? Light on, fan running?
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerAmana Model SCD22TBW. Not getting cold. Not - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
Barley any cold air coming out.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Jan 24, 2011 | Refrigerators
Freezer works refrigerator does not get cold not sure of the model not home right now am at work
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Jul 06, 2010 | GE J Series 18.2 cu. ft. Top Freezer...
Whirlpool fridge not blowing cold air but freezer
May 28, 2010 | Refrigerators
The refrigerator is not cold but the freezer seems to be working ok as food is frozen
Mar 28, 2010 | Amana Refrigerators
REFRIDGERATOR SIDE DONT KEEP COLD, BUT THE FREEZER DOES? WHY?
This symptom can be caused by many different failures, defrost system failure,( defrost heater,timer,thermostat), something blocking air transfer path to the fresh food section such as: ice build up, damper door not operating, main thermostat, check all these or have tech come in and check.
Good luck !
Mar 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer works but fridge side not cold
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Dec 06, 2009 | Amana DRS2462B Side by Side Refrigerator
Maytag P MFD2561HEB model the frig is not cold but the freezer is fine. How do we set the frig control?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 16, 2009 | Refrigerators
Amana Bottom Freezer 7 years old running but not cold.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover inside the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
heavy frost-
Aug 25, 2009 | Refrigerators
Fan doesnt stop in Amana side by side refrig.
The fan is supposed to spop while defrosting kindly check the timer contacts or wiring short
Jul 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerator is warm @ 60 degrees and the freezer is still freezing happens every so oftern
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
187 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
