Question about Kenmore Elite 45986 Front Load Washer
FH code HEt3
Washes stops beeps and flashes f blink H
it will drain and spin
ok
when retry it does the same thing
Ok we have hard water high in iron
I check the filters (farm lifestyle requires that)
What could it be?
Hoiw do I replace a balast on the inside of the bucket?
Posted on Jul 12, 2008
    President:
  • Kenmore Master
  • 2,651 Answers
Check your incoming water supply, f/h is lack of water entering machine, if you had high iron levels its quitre possible that youve clogged theinlet water valve in which case youll need to replace it, ( water supply hoses screww in the water inlet vaslve
Posted on Apr 27, 2008
Flashing and beeping red spin light. won't spin
Have you emptied the filter recently. If it's clogged, the machine can't drain or spin.
Nov 15, 2013 | Washing Machines
My wf310 1100 spin will not do a high speed spin
hi, there may be not enough water draining out on the last cycle before it spins so i'd give the pump a good luck over also check the filter if it has 1, and check the drain hose. the other fault could be the module control board this controls the motor speed hope it helps
regards
shaun
Nov 27, 2011 | Washing Machines
FH IS FLASHING ON THE WASHER AND IT HAD STOPPED WORKING ONLY 5 MNUTES INTO ITS CYCLE
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Sep 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a FH that comes on the display any ideas? please It washes to a certain point then stops showing the display but if i then put it on drain it empties ok
Might want to start with this.
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
  • If there is water in the unit:
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operatiion
Dec 20, 2010 | Whirlpool AWM8103/1 Front Load Washer
Hi Our washing mchine fills and washes ok but then stops. Will not rinse...but can be restarted on final spin. There is some water leaking underneath
Hi Ozzydj just found your posting.Do you still require help on your machine?Does your machine beep and show an error code when it stops?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Keep getting FH beeping problem...even with NO detergent...anybody got an idea? tried running a cycle in sanitation, with cup of bleach to see if its clogged due to my well water high in iron...
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Jul 15, 2010 | Whirlpool Washing Machines
Stops Mid-Cycle: Error code is blinking ?H? then ?F?
FH, in mid cycle most likely your pump is blocked, hit drain/spin and see if water drains, if not clean pump
Dec 17, 2009 | Kenmore Elite 45986 Front Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
F H beeping
ck fill hoses at rear connection and inside fill valve for debris..also be sure both faucets are fully on and there is sufficent water flow through both to washer be sure drain hose end is 30-36 inches from floor and fits loosely in standpipe ..allck ok then replace flow meter ..remove top on left side small round object with hose in each end 1 end goes to dill valve other to dispenser..flowmeter ckd for water flow into washer
Nov 01, 2008 | Whirlpool GHW9100L Front Load Washer
F/H code continues
u have to go with a good technision
Aug 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
71 people viewed this question
Sal De
fordexpert
Robert Rankin
