Question about Vizio L32 32 in. LCD HDTV
TV WILL NOT COME ON
Same problems as several other consumers. A few weeks ago my Vizio L32 started turning off on its own several times throughout the day. I would have to turn it on again. After being gone on vacation the tv will not come on at all the yellow lcd light is on. I have tried unplugging from unit and wall and waiting, not luck. TV is only 2 years old I think a tv should last longer than that in this day and age. I believe this should be a recall item by the company since alot of consumers are having the same problem.
  • 4 more comments
  • pjrt1 Apr 28, 2008
    Same problem here, only that mine has only 8 months.
  • Anonymous May 01, 2008
    My L32 started doing the same thing this month. It has turned off by itself twice and wont come on even after I unplug it. Does not respond to remote or power button.
  • Heddap May 01, 2008
    Our tv was fine in the morning, turned it off to go to work but that night when we got ready for bed no tv. We unplugged it for several minutes nothing worked. tried unplugging it for several hours still wouldnt work. Yellow light on but won't power up, changed batteries in both remotes and even plugged it into anpther outlet. We have had it 2 years. Now what do we do, but a different TV brand or what. This is very frustrating as my husband has severe Parkinsons Disease and he watches TV all day when I am at work. What do you suggest, I am desperate.
  • Anonymous May 02, 2008
    TV won't power on at all after having it 2 years. Happened after slightly bumping it into the wall. It looks undamaged, but it refuses to turn on. No lights in the front or anything.
  • exxerox May 09, 2008
    Yes I have same problem, Called Costco and they said it is probably the power supply, When I unplugged it from the wall and plugged back in, then it would power back up. Has been intermitant. Will find out next week what they are going to do....
  • Anonymous Dec 14, 2008
    We have the same problem. I will be calling Cosco, but was checking here first. The TV will turn off on it's own and then make clicking noises like it's trying to turn back on. I have to turn it on again myself either by remote or power button on TV. Then last night, it was on and I pushed the power button on the TV, and it wouldn't turn off. What is up with this? This morning, it's turning off after just a couple minutes, we turn it on and after a few seconds it goes off again. We bought it in 2005, so it's just a few years old, I was worried the screen would start going bad, not this...
SOURCE: Vizio L32
yes we did. thank you so much. we followed the directions and we couldn't believe how it worked right away. thanks again.
Posted on Jul 13, 2008
SOURCE: I need the code for vizio L32 to program One For All remote
I used the LG code 0178, to program my universal remote, it was not a One For All remote but the code worked.
I can't remember where I found the code, but give it a try!
Posted on Nov 27, 2008
djchillsnyc
  • 152 Answers
SOURCE: TV WILL NOT COME ON
hello, if it's shutting down and giving you trouble or staying on when you press the button, your set needs service. unfortunatly there isnt much you can claim if your waranty expires. there are different types of shutdowns caused by voltage spikes or drops. these sets operate at high heat and high voltages the parts go bad they loose there resistance and dont hold the proper specified loads they go haywire or dont turn on at all. so this is how they go bad even with short term use. you may want have it service. if the issue is constantly interupting your tv viewing if your set is not coming on at all. it is common with these newer lcd & plasma tv's. your fix is sort of simple a matter of exchanging or repairing a board or two. some of these fall of the stand and break instanly, i have heard of kids trowing wii's trough the screen glass. your tv is still worth its value if your main panel is good this is what the tv is built around. so if you have a circut issue maybe a button or panel that is fualty get it estimated and serviced.
hope this helps
happy holidays
Posted on Dec 21, 2008
dsacco86
  • 1077 Answers
SOURCE: I have a vizio L32 manufactured in 2005 - Won't turn on
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Posted on Jul 05, 2009
  • 1156 Answers
SOURCE: M# = VIZIO L32, LED.LIGHT Problem
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Posted on Jul 13, 2011
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
I just got a Vizio 320VL two weeks ago and I was trying to program my oceanic cable box then I turned the TV back on and it goes on and flashes the VIZIO on screen then it goes out. Can you tell me how to...
I purchased this tv yesterday and have noticed that the power cord is loose where it plugs into the tv. If I move the tv slightly I lose power.Try checking the plug.
Nov 27, 2010 | Vizio L32 32 in. LCD HDTV
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
TV WILL NOT COME ON
hope this helps
happy holidays
Dec 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Sep 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 TV won't turn on. yellow power light lit, should turn to green when button or remote is pressed, and set should come on. No response to either remote or manual buttons. No change after unplugging...
Had same prob;em. Replace main board and now works just fine. You need to take the back off and under the metal cover is the main board. The part number should start with 3320-xxxx-xxxx. You can purchase the board from Vance Baldwin. vancebaldwin.com sign in as a guest. I will warn you the cost of the board is high.
Steve
Aug 05, 2008 | Vizio L32 32 in. LCD HDTV
Black Squares on the Screen
this kind of problem is normally do of bad cable box or sat
Apr 05, 2008 | Vizio L32 32 in. LCD HDTV
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
52 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
