Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
A
Anonymous Posted on Jul 07, 2010
How do you remove the filter from Rigid wet dry vac?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 14, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4077
Points
Unscrew the 'tab/nut' at the BOTTOM of the filter and pull off the filter cartridge
1 Related Answer
Anonymous
  • Posted on May 02, 2009
SOURCE: how do i go from
can I run my sears shop vac without the paper bag, for dry pickup?
How do I remove the filter from a Rigid 4 gal portable wet/dry vac
James the attached link/video shows filter just pulls off. I also put a link to the manual and it show the filter held on with large plastic nut, which would have to be removed first.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
4 Gallon Portable Wet Dry Vac
http://www.ridgidparts.com/pdf/WD40500.pdf
Rigid WD4070 Wet Dry Shopvac Unboxing and Overview
RIDGID Shop Vac Review must have tool 2
How do I get the Rigid Wed Dry Canister vac to start?
Check the plug......I have a Rigid and have replaced the plug.
Regards,
Dennis
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
2answers
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Should I remove the filter when using it as a wet vac. I t does not seem to have much suction.
Absolutely remove the filter for wet vac. Also, if your present filter got wet replace it as the pores are now clogged and you can't save it. J.
1helpful
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
1helpful
Wet/Dry Vac Leaking
are you using a water , foam material filter?
9helpful
2answers
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
4helpful
2answers
Top Ridgid Vacuums Experts
superjulimaximo
superjulimaximo
Steve Pack
Steve Pack
Thomas Perkins
Thomas Perkins
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
