Question about Kettler Exercise Bike EX1 Stationary Bike
Executive mach iv special radio edition console not working belt missing from flywheel, not sure what type is needed
Problem with my Speedfight 50 AC. No lights front or rear and the battery is not charging. replaced stator and regulator / rectifier, still have the same problem. Voltage measured at stator connector while...
IV got a speed fight 2 100cc iv got no lights back are front only brake light works iv also got a speed fight 1 witch i'm using for parts iv changed the light switch cos the starter bottom dint work now iv swaped it it works but the old switch for lights was broke so it dint work am not sure if is as to be the same switches as there different
Jul 21, 2011 | 2006 Peugeot Speedfight 2
Timing diagram for both belts
always timing mark at the rear of cam shaft by useing special tools . for crankshaft on gear box housing there is plastic cover remove you can see mark on flywheel . there mark for timing belt tensioner try to keep not too mach tight ( you can press timing belt with your fn). for 1.8 over head camshft there is mark on camshat and camshaft bracket keep two point together for each camsh.then but the chain . for 1.2 engine use special tools rear camsh.with mark on fly wheel
Jun 19, 2011 | Volkswagen Camper Cars & Trucks
Is there a version of Bible Library Edition compatible with windows 7
If a program cannot be run under Windows 7 because of compatibility issues, which is the case with Bible Library Deluxe Special Edition 5.1, you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Nov 25, 2010 | ValuSoft The Bible Library Deluxe Special...
How to fit cam belt to renault megane 1.5 dynamique diesel 2004
not difficult with the right equipment ,firstly you will need a special tool to lock the crankshaft in place ,then another special tool than aligns the tdc this goes through the cylinder block at the front right hand side by taking a bolt out in the block thats just in front of the bell housing .The special tools cost an arm and a leg trust me and then the pulley bolt has to be pulled up to 130lbs ,the bottom pulley does not have a keyway so without the right tools its very easy to let the engine turn and clout the valves which breaks the camshaft bearing caps with relative ease .the kit you need can be bought and its kit number AST4390 plus the locking pieces for the flywheel .This is not a weekend mechanic type job ,yes its easy with the right tools but even myself will slacken tensioner and remove the cam before i start so valves cannot catch when i turn engine over on starter with a big bar on the pulley nut ,then change the belt then with assistant holding a snap on heel bar in the flywheel ring gear whilst i hammer the bottom pulley bolt with the air wrench ,then use the 80cm knuckle bar and have a good grunch to make sure its really tight or it WILL TURN and the valves hit and break and imbed themselves in the pistons and smash the cam bearing caps .This is not a job for the faint hearted ,their is a timing mark on the flywheel looking from the top through a elongated hole and TDC is a longer tooth ,the inspection slot is about 3cms down from the crank sensor
Jul 30, 2010 | 2004 Renault 181
What folder is reboot in
  • Power is turned on.
  • Open Firmware code is executed.
  • Hardware information is collected and hardware is initialized.
  • Something (usually the OS, but also things like the Apple Hardware Test, etc.) is selected to boot. The user may be prompted to select what to boot.
  • Control passes to /System/Library/CoreServices/BootX, the boot loader. BootX loads the kernel and also draws the OS badges, if any.
  • BootX tries to load a previously cached list of device drivers (created/updated by /usr/sbin/kextcache). Such a cache is of the type mkext and contains the info dictionaries and binary files for multiple kernel extensions. Note that if the mkext cache is corrupt or missing, BootX would look in /System/Library/Extensions for extensions that are needed in the current scenario (as determined by the value of the OSBundleRequired property in the Info.plist file of the extension's bundle.
  • The init routine of the kernel is executed. The root device of the booting system is determined. At this point, Open Firmware is not accessible any more.
  • Various Mach/BSD data structures are initialized by the kernel.
  • The I/O Kit is initialized.
  • The kernel starts /sbin/mach_init, the Mach service naming (bootstrap) daemon. mach_init maintains mappings between service names and the Mach ports that provide access to those services.
Mar 08, 2010 | Apple MacBook Mac Notebook
Loud noise and appears the belt is slipping
Generally you will find soil and string of some sort wrapped around the drive spool. Make sure you unplug it before starting and it might be quite hot.
Dec 12, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
How to install timing belt on 1998 vw beetle
Instructions
Things You'll Need: · Set of quarter-inch drive sockets Quarter-inch drive ratchet Set of half-inch drive sockets Half-inch drive air gun Set of metric wrenches Special tools for holding camshaft timing #2065-A and injection pump #2064
Step 1
Remove the accessory drive belts and the accessory drive belt tensioner. Remove the upper timing belt cover and the valve cover. Turn the crankshaft clockwise until the No.1 cylinder is atop, dead center, with the flywheel timing marks aligned.
Step 2
Install the special tool setting bar (#2065-A) on the rear of the camshaft. If it does not fit, turn the crankshaft once more and line up the timing marks again in the hole of the transmission housing.
Step 3
Insert locking pin #2064 into the injection pump to hold it in position. Remove the crankshaft pulley bolts, the crankshaft pulley and the lower timing belt cover. Loosen the tensioner pulley nut and allow the tensioner to move away from the belt. Loosely tighten the nut to hold the tensioner out of the way. Remove the top guide pulley and the timing belt.
Step 4
Make sure that the timing mark on the flywheel is lined up and that the camshaft setting bar and injection locking pin are in place. Loosen the camshaft bolt a half turn and tap the sprocket with a soft mallet to loosen it off its taper. The sprocket should move freely. Install the top guide pulley and torque to 18 foot pounds of torque.
Step 5
Install the new timing belt, starting on the right side and working counterclockwise. Keep the tension on the right nontensioned side. Loosen the tensioner pulley nut. Using the two-pin wrench, turn the tensioner pulley clockwise until the notch and raised mark are aligned. Torque the tensioner pulley nut to 15 foot pounds of torque. Make sure the flywheel timing mark is still aligned.
Step 6
Torque the camshaft bolt to 33 foot pounds of torque. Remove the locking pin from the injection pump and remove the camshaft setting bar. Turn the crankshaft two turns and check the alignment on the flywheel. Make sure that the setting bar can be inserted easily and that the injection pump locking pin can be inserted. Install all components in reverse order of removal and torque the crankshaft bolt to 18 foot pounds of torque.
My Recommendation - Pay an authorized VW mechanic $500 to replace the timing belt water pump an tensioner, and sleep better knowing that the job was done right. Just too many places for a novice car mechanic to screw up. jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Oct 06, 2009 | 1998 Volkswagen Beetle
TRIGGER IN SQL
A trigger is a special kind of stored procedure that automatically executes when an event occurs in the database server. A trigger is really an event handler. SQL Server allows users to create triggers (event handlers) for 3 types of events:
  • DML Event - Occurs when a DML (Data Manipulation Language) statement: INSERT, UPDATE or DELETE, is executed.
  • DDL Event - Occurs when a DDL (Data Definition Language) statement: CREATE, ALTER, or DROP, is executed.
  • Logon Event - Occurs when a user logins to the Server.
There are 3 different types of triggers (event handlers) based on the types of events they are triggered by:
  • DML Trigger - Executes in response to a DML event.
  • DDL Trigger - Executes in response to a DDL event.
  • Logon Trigger - Executes in response to a logon event.
Jul 03, 2008 | Microsoft SQL Server 2000 Standard Edition...
Kettler Exercise Bike  EX1 Stationary Bike Logo
59 people viewed this question
Top Kettler Cycling Experts
Eric Hidle
Level 1 Expert
dante
Donald Ayers-Marsh
Are you a Kettler Cycling Expert? Answer questions, earn points and help others
