Question about Kenmore 24032\24036 Top Load Washer
Our Kenmore Elite Top-loader heavy duty King-sized machine is 9 years old and it just stopped spinning and does not agitate much. It is also making a louder noise than usual. Is this worth fixing? What parts may be needed?
  • malve001 Jul 12, 2010
    Could it be just the motor coupler? That would be alot less expensive to fix?
  • 6,784 Answers
HI. I suspect that your coupler has failed, however, I will need the entire model number to calculate the repair price. Please post the entire model number, asap.
Posted on Jul 12, 2010
  • Michael Masters
    Michael Masters Jul 12, 2010
    HI again. I really need that model number, if possible.
    With that said; Let start our troubleshooting here:
    The first action is to test the lid switch. The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed. Aside from electrical problems, the switch may suffer from a mechanical problem. The lid may have a striker which depresses the switch when the lid is closed. Make sure the striker is functioning and aligned with the hole over the switch. Inspect the switch and make sure the metal strip is not bent out of position (if present). If your switch uses a mercury switch, make sure the mercury envelops the internal contacts when it is in the closed lid position. Your design may differ, so inspect it for proper operation before proceeding to the electrical testing.There are two primary types of lid switches. One type on which you can directly test the terminals on the switch and another style where you have to test it at the wiring harness. In either case the method for testing the switch is the same. If a wiring harness is used, separate the two pieces of the harness and test the side of the harness that connects to the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.Some lid switches also have a fuse, you can visually inspect the fuse or test it for continuity with a multimeter. If the fuse is bad, replace it with one of the same rating. If the lid switch is operational, i would move on to the next possible issue. This will be the motor coupler.
    Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or trio-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission.A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
    To get started, you will need to disassemble the cabinet and Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor. Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
    • NOTE:I would suggest to check the following while you are in the area for faults as well(((Clutch,motor,Gear case))). inspect these areas thoroughly for any visible damage.
  • 11,896 Answers
If it is 9 years old, I would probably consider another machine. I say 5 years and newer is worth it. The tub/agitator bearings are wearing out. They are very time consuming and require special tools to lift the tub and pull the bearings. To have someone else do it runs about 4-5 hundred dollars.
Posted on Jul 11, 2010
  • Nate Stansfield
    Nate Stansfield Jul 12, 2010
    Bearing, coupler, or motor fault are the number one causes of the tub or agitator no spinning.
Kenmore elite heavy duty king size top loader water will not stop running to the liquid detergent dispenser even when the tub starts filling Causing the machine to over flow
could be the water valve not closing properly, try unplugging the machine see if the water stops if not replace water valve. Also check pressure hose for cut and pin hole thx
Mar 01, 2014 | Washing Machines
Need to make spin the agitator on a Hotpoint Heavy Duty Washer
Drive belt broken call GE Parts for new belt , They stock for all makes ,,
Aug 17, 2012 | Hotpoint Washing Machines
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
Washer is a Kenmore Elite Heavy Duty King Size Quiet Pak 3 Spd Motor/6 Spd combination do not have model number about 9 years old problem is the system will not agitate corretly. It will operate for a few...
Hey Steve!
To answer your question, no. They usually don't have a Thermal fuse. They aren't that suseptable to overheating (most of the time). You most definately would want to have a technician service this unit. You REALLY have to be experienced to work on these front loaders. They are LOADED with electronics that monitor and control everything that happens with the unit.
Dec 14, 2009 | Kenmore Washing Machines
My kenmore elite oasis keeps stopping on spin and flashing ul it is a top loader king size capacity
UL = uneven load.
Re-distribute clothes and re-try.
If still no-go... the load balance sensor is likely to blame.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Heavy Duty King Size Capacity Top Load Washer Won't Spin/Agitata
I am sorry to say that you WILL need a tech to come out and service this unit.  From what you are telling me it is either a dead short in the motor, OR one of the conntections got wet and cause a short.  BUT I would put my money on the motor, since this is a direct drive unit.  Sorry
May 26, 2008 | Washing Machines
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
