Question about Eton Microlink FR160 AMFMWeather Radio
Can't charge i-pod or phone
I try charging my i-pod and phone by using the crank but nothing happens.
  • 17,130 Answers
First of all use a voltmetter to determine the output voltage of the unit while cranking. If the voltage is not enough you will need to open the unit to check if the induction in the system is faulty. Check the wires for continuity and also check the coils. Unless the coils are open you will not have any issues. Once the power is coming then you must check with the terminal for connection issues. I think you will be able to charge provided your charger is not defective. hope I could help? Good day
Posted on Jul 15, 2010
When i turn key gauge pod lights up but nothing else happens
neutral try connect battery terminals charge battery,starter hanging up
Aug 28, 2014 | Polaris 2006 Sportsman 500 HO EFI
BlackBerry PlayBook will not charge or turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 07, 2012 | Cell Phones
My apple ipod touch will not charge. Nothing will come across the screen. not even a view if the battery. I've had it charging hooked to the USB cable to my computer for at least 30 minutes and still...
it might be that the charging space that makes the i pod charge is faulty due to always removing and fixing the charger in the charging space.The charging space might have been damaged or the voltage of the light i your area fluctuates and might have affected the charger too.
Check the charger with another i pod to confirm if is the charger or the charging space that needs to be replaced.
Take care.
Mar 15, 2010 | Apple iPod touch
Phone was working fine then battery went out of charge,when I got home I PLUGED IN MY CHARGER AS NORMAL BUT NOTHING I HAVE TRIED SEVERAL TIMES TO GET TO GHARGE BUT NOTHING.
Try these and tell me the result.
1. Try to charge from a different charger.
2. Use another battery and try to on the phone.
3. After plug on the charger press power on/off button for a while. If nothing happened on your mobile after use these 3 tips then visit Nokia service center for installing the operating system on your phone. If the OS is corrupt then the mobile going under dark. No movement, no signaling of charging nothing. Even you can't update it from internet right now. Because the phone memory is fully dead. Its happened with all mobiles if the OS corrupt. Its was happened also in my Nokia N73.
Thanks &waiting for your reply.
Feb 04, 2010 | Nokia N95 Cellular Phone
My ipod nano wont do anything
try reseting it with holding down the menu and center button. Your warrenty will have been voided due to the liquid damage though so if you cant get it working with the reset your gunna need a new one.
Apr 17, 2009 | Apple iPod nano
I pod nano will play but not take a charge
Well then you cannot charge your i pod on the bose system *******
Mar 01, 2009 | Apple iPod nano 3rd Generation
Razr v3 drained battery charging
the desk top charger wont be working for your device and I suggest you to replace the battery on to another mobile phone and try charging it
Dec 26, 2008 | Motorola Mobility RAZR V3
8300 will not charge
My charge port is broken out of my 8300. I bought an extra battery and an external charger off of eBay for a little of nothing. You can also by a pod that will charge your Blackberry. The two gold tabs on the back of your device beneath the battery is an external charger connection for a desktop pod.
Oct 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Display shows "Not Registered"
1. Remove battery from phone, and unplug from charging cable
2. Unplug Phone base
3. Hold Page button on base and plug it back in. While holding page button wait for in use light to go solid. Once solid unplug base.
4. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
5. Press 0
6. Unplug power from phone pod
7. Hold clear button on the phone pod and plug in charging cable until you see ----- on the screen.
8. Hold the page button on the base and plug it in, Hold page button until the in use light blinks. Let go of page button.
9. Press 9 on your phone. If it says Reg o it is finished. If it says Reg fail try again if it fails twice please call Tech support.
10. Replace Battery
11. Make a test call
Oct 05, 2007 | ClearOne Communications Max Wireless...
Apple mini i-pod
Try another usb port, but not in a non ac powered usb extension hub, as I Pod's need to be used in powered usb. Older pc's tend to have trouble powering the usb ports enough for the I Pod to be recognised. It may also be a voltage problem, disconnect any other usb peripherals connected and try again.
Jan 29, 2007 | Apple Mini IPod
Eton Microlink FR160 AMFMWeather Radio Logo
75 people viewed this question
Top Eton Audio Players & Recorders Experts
Mike carichael
Level 1 Expert
k24674
RobertFonner
RobertFonner
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
