Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Model KSFS25FKWH00 ice maker/ chilled water
The ice maker still makes ice but the crusser does not work and the chill water does not work. The lights on the front panel turn on and off when the buttons are pushed, but nothing happens.
  • 11,896 Answers
These two problems can very well be related. The water line which has a filter that often needs to be changed or it plugs up is connected to both units. There also run to the same circuit board which provides power to both of them that can fail but testing with a meter may be needed to determine if the units are getting power. One for the water fill and one for the ice maker. You can go to partselect . com to view diagrams of the internal parts of your unit as well
Posted on Jul 11, 2010
Why my Taylor yogurt machine not freezing the yogurt. Model number 339 -58
if cooling light is coming on ck to see if chill plate is getting cold after a few minutes , also visually verify that agitator blades are moving mix around and over chill plate
(chill plate is inside round tunnel that mix bars go thru )
Jan 21, 2016 | Taylor Ice Cream Makers
Ice maker works but no water out of water dispenser?
Hi
You have not supplied the make or model of your fridge and so I can only offer a generic response.
Most ice-makers, chilled water dispensers are reliant upon a water stop valve that make a distinctive click when operated.
Does it click when you dispense water?
If not, then assuming the ice dispenser works (indicating the activate button is working), then the water valve has possibly failed (or less likely the wiring somewhere in between).
Dec 15, 2013 | Refrigerators
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker is on but is not producing ice
The ice maker is probably not getting water. Have you heard the water valve click on and off to allow water to flow to the ice maker? If you get chilled water from the fridge, the ice maker's water valve will probably sound very similar to when you dispense chilled water. Try the water to listen for it. Then, listen for it over the course of an hour or so to determine if the ice maker is doing the same thing. If you hear it - then there may be a blockage in the line or filter.
If you don't have provisions to get chilled water from your fridge (ice only) or notice that you can't get water from your fridge any more: Make sure the water supply is on and.. that supply line isn't kinked or got crushed when the fridge was pushed back into position. This is a pretty common occurrence. If you don't hear any water valve clicking, the valve itself may have failed or there may be a problem with the electrical circuit. Hopefully, you won't have to got beyond this, but if so - let us know.
May 24, 2010 | GE GSS25LGM Side by Side Refrigerator
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
53 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
