Question about Sanyo EasyStreet NVM-4370 Car GPS Receiver
Gps not turning on/starting
It's been plugged in to charge power is on and it's just flashing the SANYO start up window, I don't think it's charging because the light on top of power button is not turning on red, It won't even start up, how can I fix this issue?
You must use the sanyo charger with this gps if the battery is really low or drained. other usb chargers WILL NOT WORK. Has to do with how they designed the startup voltage and amps.
Posted on Aug 20, 2010
I have the same problem. It may have something to do with battery. Try to charge it via your car. Or get a Garmin and never buy a Sanyo GPS again.
Posted on Jul 19, 2010
Hi, my Sanyo NVM-4370 GPS does not turn on. I plug it into the car and all it does is blink on and off showing the blue Sanyo back ground. It will not go further then that. I have hit the reset tab, but...
You MUST use the sanyo charger with this unit. Other usb chargers, yes, even your computer, WILL NOT WORK if the battery is very low. If you have left the power button ON and just turn it off with the upper "menu" button, your battery will last about 12 hours without it being charged. Also, as I sure you are aware, the off/on must be in the on position for it to charge. Hope this helps ya .... BTW: I think the $79.00 for the Update is way out of range for this unit. $15 - 22.00 is more of a reasonable price. I got mine at RShack for $99. NEW
Aug 15, 2010 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Garmin 205 how to charge on computer?
follow the steps below:
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disappear.
Good luck.
May 27, 2010 | Garmin nuvi 205W GPS Receiver
The system flashes off and on
You must use the harger from the unit , If it is Flashing "SANYO" then off the Bat is dead , it must be charged using the 12v charger . It will not get enough power from A USB port .
Jan 02, 2010 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Why does my magellan maestro 3100 turn off immediately after I turn it on?
Hi catscan990 Its probably not charging, but plug it into a known good charger and let it charge for a few hours then see if it starts.
press and hold the power button for upto 10 seconds or untill it starts.
If it starts normally and is still plugged to the charger, go to the main menu/options/power and see if the changing indicator is moving from side to side. If it is not moving,
The following Magellan 800,860,2000,2200t,2500,(crossover) 3000,3050,3100,3140,4000,4040,4050,5310 and the 6000t are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port.
You may also have another issue with the screen but you need to find out why its not charging 1st.
You can get it repaired
here
Or buy the port here
Let me know if you need further help!
Bill
Sep 19, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
The battery for my sanyo digital camera won't charge.
I had this same problem with my Sanyo. I went on E Bay and purchased a new battery.. It was about 8 dollars and shipped from China. But it worked when I put the new battery in and charged it.
Jul 30, 2009 | Sanyo Xacti VPC-T700 Digital Camera
Sanyo 4370 canot start code10
Your GPS battery is dried out, use the original car charger or one that can output at least 1.5 Amp.
Jul 20, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Sanyo EasyStreet NVM-4370 Car GPS Receiver Logo
223 people viewed this question
Top Sanyo GPS Experts
perdue40
Rochell Cruz
Are you a Sanyo GPS Expert? Answer questions, earn points and help others
