Question about Kenmore 22422 Top Load Washer
KEMORE WASHER 22442 NOT DRAINING - Kenmore 22422 Top Load Washer
  • oldguy5 Jul 12, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. WILL IT SPIN???? HAVE YOU TRIED A DIFFERENT CYCLE???? CAN YOU HEAR THE MOTOR???? CAN YOU HEAR / SMELL ANYTHING UNUSUAL???
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. WILL IT SPIN????? CAN YOU HEAR THE MOTOR???? CAN YOU HEAR / SMELL ANYTHING UNUSUAL??? HAVE YOU TRIED ANOTHER CYCLE???
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
There's basically a solenoid that should open up to drain.
Please consult your manual for troubleshooting as this model may need a new transmission?
Posted on Sep 28, 2010
My kenmore elite washer model # 110.24082200 is leaking from bottom. No visible leak from back panel acces...
my kemore whasing machine model10010 .25864400is not drain all c los left sam wather in dram and sound of water pamp like cenot turne tenks Bruno
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 90 Series Heavy Duty Top Load Washer Model 110.28922790 water fills in tub and it's draining at the same time. Won't go through the normal cycle just keeps filling and draining. Any help...
You may have a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Apr 17, 2010 | Kenmore 22442 Top Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Kemore washer will not spin
Is your drain pump blocked?
The machine will not spin until the water is drained.
Some models have a small door at the front bottom of the machine. Open the door and unscrew the coin trap. There maybe some debris in there?
Also check the end of the drain hose where the water comes out. Sometimes the foreign material goes through and blocks at the end there.
Hope this helps!?
Jun 19, 2009 | Washing Machines
How do I replace a lid switch on a kenmore heavy duty washer model # 22442 my switch is in pieces
I just stuck a wooden clothes pin in the hole to keep the little level in check. My landlord's washer had that problem and he didn't want to pay to fix it. It ran great for many more years after I stuck the wooden clothes pin in it.
Feb 24, 2009 | Kenmore 22442 Top Load Washer
Kenmore 22442 not spinning unless you physically help it along
Sounds like a worn belt problem!
Call service now before it gets worse and cost you a lot more money!
You'll be okay!
Electronic problem. just call service.
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Give me a good rating on this site , FIXYA.COM
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 23, 2008 | Kenmore 22442 Top Load Washer
Kenmoore 22442 Washer will not drain or spin
I'm having the same problem with mine. Did you replace the lid switch or timer?
Jun 11, 2008 | Kenmore 22422 Top Load Washer
Kennmore 22442
last belt drive kenmore came out in 1986..so doubt you find a belt on it unless you have a calypso model..if you have pump out but no spin motor to gearcase coupling is probably broke
May 05, 2008 | Kenmore 22442 Top Load Washer
Kenmore 22422 Top Load Washer Logo
53 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
