Question about Heath Zenith SL-6136-WH Basic Solutions Wireless Switch and Plug-in
We have old wireless door bell units We need one push button and one battery chime to match 20 year old set.code Y
  • 10,865 Answers
Hello. There is a nice collection of these wireless units at both Home Depot and Lowes. OR you can go to the company's home page and order direct http://www.heath-zenith.com/ J.
Posted on Jul 11, 2010
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mar 09, 2011 | Desa International White Wireless Plug In...
I have a door chime SL-6195-RX with outside door push button. I have changed batteries in both units and still does not work.
The contacts in the outside push button unit may need cleaning. They do get dirty over time. If that doesn't solve your problem you can contact the Zenith Company, who is now is the manufacturer for tech service issues. 800-858-8501.
Hope this helps solve your problem.
Mar 07, 2011 | Desa International White Wireless Plug In...
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
Aug 31, 2009 | Desa International White Wireless Plug In...
I have two door chimes with the same frequemcy, but different codes. I need to place the chimes in different rooms as I am hard of hearing. How do I match both codes so that they ring at the same time when...
You need to change the pin configuration in both the remote buttons to match each other, (as well as the bell unit) just make sure they match on both bell units. Also, since one works just use that configuration and change the button pin configuration that does not work to the button that does on the other button unit.
Mar 03, 2009 | Desa International White Wireless Plug In...
Door chime code for GE model 1601S &1602S
Hi there. I think I have the same GE chime. It has a series of 4 dip switches on the bell (base) and also in the switch unit. Just make them the same. On mine for example, switch # 1,2 & 4 are up (on) and #3 is down (off). Any combination of 16 codes should work as long as both units are the same. Just as an aside, I had a problem with mine working intermittently, then mostly not at all. It was the actual pushbutton switch inside the button unit. Luckily, I replaced the micro-switch and it's working again. Also during cold wet weather, the 12v battery gets depleted faster than normal probably due to moisture inside the switch unit. I taped a piece of plastic from a sandwich bag over the switch unit to help keep water out.
I hope this helps.....
Nov 22, 2008 | Home Security
Heath Zenith SL-6136-WH Basic Solutions Wireless Switch and Plug-in Logo
Top Heath Zenith Electrical Supplies Experts
lakeareaserv
Bob Kirkwood
Gene Haynes
Are you a Heath Zenith Electrical Supply Expert? Answer questions, earn points and help others
