Question about Dell Dimension 3100 PC Desktop
Cd dvd tray will not open or close and the light is dark. How do I fix this?
  • 6,826 Answers
Open up the system and look at the wiring connections area.
This might be disconnected. If not, replace the cd/dvd mechanism,
as the cd/dvd player/writer is probably burnt out.
Also, check the BIOS that it is recognized by the motherboard.
Good luck on this one.
Posted on Jul 11, 2010
The CD drawer has gotten off track and won't open or close
look under the tray and see if there is a track in the bottom of the tray. If there is, there should be a corresponding pin that has to go in that track. Most cd/dvd mechanisms are designed this way.
Feb 24, 2014 | Audio Players & Recorders
Tip
Matsui DVD-122 VCD Fix
Matsui DVD-122 DVD Player VCD Playback Fix
Would you like to unlock your Matsui DVD-122 DVD Player to play VCD's?
Follow these steps to unlock your Matsui DVD-122 DVD Player:
  1. Press the Open button on your remote control to open the drive tray
  2. Place an audio CD in the drive tray
  3. Press the Open button on your remote control to close the drive tray
  4. Press the Menu button on your remote control
  5. Press the 1 button on your remote control
  6. Press the Index (1-All) button on your remote control
  7. Press the Open button on your remote control
  8. Press the 1 button on your remote control
Your Matsui DVD-122 DVD Player can now play VCD's.
I hope that helps.
___________________________________________
Matsui DVD-122 Region Free Fix
on Apr 25, 2010 | Televison & Video
Tip
Tevion DVD-200 VCD Fix
Tevion DVD-200 DVD Player VCD Playback Fix
Would you like to unlock your Tevion DVD-200 DVD Player to play VCD's?
Follow these steps to unlock your Tevion DVD-200 DVD Player:
Your Tevion DVD-200 DVD Player can now play VCD's.
I hope that helps.
Tevion DVD-200 Region Free Fix
I keep getting the close the cd/dvd guide
When you flip the main cover up, and flip the CD/DVD tray down, look at the cartridge color guide label (the colored dots). See the LIGHT CYAN dot? Directly across from that dot around underneath the gray cover is supposed to be a little plastic fin. That fin pushes the sensor switch in the CD/DVD tray to let the printer know if it is open or closed. If it breaks off, then the printer always thinks the tray is open. If it's broken off, you will have to either stick a toothpick or something into the switch, or glue a new thin piece of plastic in its place.
Mar 01, 2010 | Epson Stylus Photo R320 InkJet Printer
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
Jun 03, 2009 | Technics SL-PD687 5-Disc CD Changer
CD/DVD Tray open; Close Tray to print
This solution is taken from the HP website.
Follow these steps to print on a CD or DVD.
  1. Make sure that the CD/DVD tray is completely closed (completely inserted into the product).
    NOTE: Make sure that the side of the tray that holds the CD/DVD is inserted into the printer first.
  2. In HP Photosmart Essential, click the Print tab.
  3. Click Printer Settings and then click Advanced to open the printer properties.
  4. In the properties, click the Features tab.
  5. In Paper Type , select Printable CD 120mm .
  6. In Source , select the CD/DVD tray .
  7. Save the settings and then again attempt to print on the CD or DVD.
Feb 05, 2009 | HP Photosmart D5360 InkJet Printer
Cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
Jun 30, 2008 | HP Pavilion dv9000z Notebook
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Dell Dimension 3100 PC Desktop Logo
62 people viewed this question
Alun Cox
