Question about Dell 1815dn All-In-One Laser Printer
I need a user manual for a Dell MFP 1815 dn - Dell 1815dn All-In-One Laser Printer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
Here is the Dell online user guide for the 1815dn
http://support.dell.com/support/edocs/systems/prn1815/en/index.htm
Posted on Jul 16, 2010
Dell MFP 1815dn continuously feeds paper when printing
There might be a paper jam or issue with the drum .. please remove the jammed paper or contact authorised dell support
Oct 05, 2016 | Dell Laser MFP 1815
I have a Dell laser mfp 1815 dn. There is not an option to scan to a pdf. It will scan to a bitmap which is not what I need. How do I get it to scan to a pdf?
When you save the scan select pdf from the pull down menu "Select Type of Document" in the Save Dialog.
Hope that helps.
Jul 23, 2011 | Dell 1815dn All-In-One Laser Printer
Show me how to replace a fuser in a dell mfp 1815 dn printer please
Pull down the rear door. There should be 2 screws on either side.....remove them....look for 2 more screws towards the bottom. Remove them....the entire rear plastic of the machine should pull off...exposing the fuser. Remove the screws holding the fuser in place. Pull the connectors from the power supply below and you should be able to pull the fuser out! If you need a fuser you can get one at www.getthatpart.com they have good used fusers at good prices....you can also call them at 410-374-1261
Oct 25, 2010 | Dell 1815dn All-In-One Laser Printer
How do I unlock the scanner on a dell laser MFP 1815 dn printer. I can't fax or copy anything. It says the scanner is locked.
There's a little blue toggle switch where the copies/scans come out from.
Pull the blue switch toward you, turn off the printer, wait a few seconds, and turn the printer back on.
Aug 27, 2010 | Dell Printers:Dell MFP Laser Printer...
I dont know how to send a fax using the Dell laser MFP 1815 dh
Here is a link to the Dell website where you can download the user manual for the MFP 1815dn. I just looked and it has a complete section on how to use your fax...
Sep 10, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815 dn - bogus front door open message
Hey, make sure the front door is shut, if it is, you most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS.
Sep 08, 2009 | Dell 1815dn All-In-One Laser Printer
MFP 1815 D Unlock Scanner message
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
Jul 13, 2009 | Dell 1815dn All-In-One Laser Printer
Dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Jul 06, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
989 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
