Question about Coleman 10' X 10' Sundome Tent 9160K101
Interior lights, appliances work fine when plugged
Coleman Tent trailer Utah model 1999 . Interior 12 volt lights, appliances work fine when plugged into a 110 v AC power source, they do not work when attached to a fully charged battery on the tongue. Any ideas as to the problem?
  • Coleman Master
  • 6,674 Answers
Check for a faulty inline fuse or circuit breaker at harness attached at front of trailer. Follow positive wire back to trailer.
Posted on Aug 27, 2010
1978 bonair tent trailer has a 110 plus 12 volt system but wires were cut from coverter. I would like a drawing of how to reconnect wiring system
Building their first recreational trailers in 1983, Bonair offered a wide range of small to medium-sized products. Bonair concluded production of recreational vehicles after the 1999 model year.
It will be difficult to find manuals for legacy RVs. Try an online enthusiast forum.
Jun 24, 2016 | RVs
Hello I have a 1999 coleman santa fe pop up tent trailer all the lights inside and the one exterior light by the door stopped working. All the other electrical plug-in s work as does the refrigerator. We...
Unfortunately, sounds like you're gonna need to do some hunting. Starting with the receptacle, or light, closest to the fuse box, unscrew the light fixture or outlet cover and pull the outlet out. You need to look for wires that are discolored or disconnected. If it's as hot as you say it is, something probably melted. Goal is to trace the wires all the way to the fuse box, you will find your problem.
Jul 05, 2014 | Cars & Trucks
Replacement Pole for Coleman Oasis Cabin Tent model 2000000583
Coleman may be contacted toll-free at 1-800-835-3278. Replacement parts are available from them.
Apr 01, 2014 | Coleman Outdoor Products Coleman Oasis 16...
I want to use this Transformer to power my 12 volt lights in my trailer using a 7 blade connector that is already installed on my trailer. How do I connect the wiring n the ac nle
The two wires are meant to be connected to the 120 volt source. The box or the papers with the transformer should tell you which two of the three wires provides the 12 volt output. If not connect the two wires to the 120V source - Be CAREFUL! - 120V is dangerous. Then try, one at a time, touching each of the three combinations of wires (1&2, 1&3, 2&3) to the contacts on a 12 V incandescent lamp (very bottom and threaded side) the 12V pair will give you the brightest light. The other two are 6v.
I can't address the 7 blade connector without more information. I suggest that you go to a place that sells trailer parts.
Not knowing anything about your trailer I don't know if a 2 amp (2000 ma) transformer will supply enough current to do the job.
Nov 19, 2013 | Philmore TR212 12 Volt AC Power...
110 to 220 ??? power from a common outlet to travel trailer
A TRANSDUCER WILL STEP 220 DOWN TO 110 .
I BELIEVE AN INVERTER WILL BOOST IT FROM 110 TO 220 A ALL IN ONE TRANSFORMER WILL WORK
Jun 30, 2013 | Cruiser RV 2013 Fun Finder X X-214WSD
Interior lights inop jayco pop up tent trailer
I have a 99 Jayco Eagle Tent Trailer and had this issue of no interior lights. I discovered that the kill switch was stuck in the off position. On my trailer, it was located on the inside of the roof about 1 ft. from the end of the roof where the electrical wires come down the black protective tubing. This is on the road side of the trailer.
Mar 06, 2013 | Sport & Outdoor - Others
I have a Centurion power converter 30 amp for a bonair tent trailer.I have power to my plug outlets when i am plugged into household power but no dome lights which i assume are 12 volt.Would this mean the...
the converter might not be working and is letting in too many volts and over powering it to the point of not working var fctb_tool=null; function FCTB_Init_18d1597bc4e042ef83fc9da550d91841(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_18d1597bc4e042ef83fc9da550d91841(document['FCTB_Init_2f479b557e0942269c917ba4c26f8cca']); delete document['FCTB_Init_2f479b557e0942269c917ba4c26f8cca'] var fctb_tool=null; function FCTB_Init_6055a1a4f8f0424782d2160b7b182f51(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_6055a1a4f8f0424782d2160b7b182f51(document['FCTB_Init_ad434a04dea2406ca738d57fb96fd227']); delete document['FCTB_Init_ad434a04dea2406ca738d57fb96fd227']
May 05, 2011 | Sport & Outdoor - Others
I have a coleman powermate 6250 generator with a 4prong 220v female plug on the power panel. My travel trailer has a 3 prong male plug. How can I convert my generator or is there an adapter that I can...
You do not want to convert anything to a 220 v connection !!!! Your RV is 12 volt DC and 120 volt AC.
Use a 30amp female to 15 amp male adapter to plug in to regular household receptacle on generator. Available at hardware store and RV stores.
Apr 27, 2011 | Coleman Powermate Premium Plus 6250W...
Coleman 10' X 10' Sundome Tent 9160K101 Logo
564 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
Vernon Taylor
David Payne
David Payne
john h
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
