Question about Toshiba SD C2512 (SD-C2512) Internal DVD Drive
I have the Same Problem, it can play cd/dvd that are already burn but if i put in a blank it say cant read from this disk
  • 75 Answers
You can try to delete upper and lower filters for your system. go to start>run>type in regedit click ok> start looking for this parth HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318},when click on the folder look on the right column and look for upper/lower filters and delete it. restart system. Try updating the firmware of the optical drive depending on the model.
caution:be careful with deleting registry for your system this might affect your operating system functionality.
Posted on Jul 22, 2010
Goes straight to burn and doesen't copy
Which Program? There is a difference between Burn and Copy.
Copy means you have a CD or DvD that already has something on it such as a music CD or a movie DvD and you want to copy it. The system normally reads the CD or DvD and copies the contents to disk then asks you to put in a blank CD or DvD to make the copy.
Burn means you have Data Files, Documents or Music that is already on the disk drive and you want to put it on a Cd or DvD. Normally you just put in a blank CD or DvD then either Drop and Drag, Browse or Copy and Paste the files you want on the CD or DvD.
Mar 30, 2012 | Computers & Internet
Program says dvd+r incompatible with toshiba dvd player
Some DVD players will read 'DVD-R' ("minus-R") disks.
Some DVD players will read 'DVD+R' ("minus+R") disks.
Some DVD players will read "both" types of disks.
So, if you're burning onto a DVD+R disk, you won't be able to "play" the disk on your Toshiba DVD-player.
Instead, buy "blank" DVD-R disks, and write on them.
Apr 05, 2010 | Computers & Internet
Will burn cd-r but kicks the disk out whe I put in a blank DVD-r
Sorry but your burner is a CD-RW/DVD-ROM
this means you can burn CDs and play DVD
you cannot Burn DVD with this device.
info link here
http://www.cdrinfo.com/Sections/News/Details.aspx?NewsId=7470
Please don't forget to rate me : )
Oct 01, 2009 | Toshiba SD R1312 CD-RW/DVD-ROM Burner
Toshiba sd-r2002
I'm very late to your question, but the problem is that this drive doesn't burn DVDs (i.e., it was not designed to do that). It's a CD-RW, DVD-ROM (read only).
Apr 03, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
You can burn only on the blank CD-RW or any blank CD.
Jan 17, 2008 | LG X-Note LM50 Notebook
My dvdrom drive wont let me access the drive
ITs a dvd rom drive. It will not burn blank dvds
in order to burn, it has to cd-r/cd-rw/dvd-r/dvd-rw. If a drive cannot write to a blank disc, it will eject it. Rom drives read only (Read Only Memory), Combo drives- burn cd's only read dvd's, and super drives both read and write to cds and dvds.
Oct 23, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Cd dvd wont play
Many of the older DVD and CD players will not play disks recorded on a computer. This has to do mainly with the laser optical response.
There were several manufactures that manufactured their laser unit with a built in filter that would not allow their player to read non pressed CD disks (disks burned with a home computer).
When buring DVD's or CD's, use the slowest possible speed for the burn to have the highest readablity and least data errors possible for the medium.
Jerry G.
Mar 09, 2007 | JVC KD-AVX1 Car DVD Player
Toshiba SD C2512 (SD-C2512) Internal DVD Drive Logo
83 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
