Question about GE Refrigerators
The refrigerator is a side by side Profile/Artica model PSS27SHNA. The condenser is freezing up until an ice block is formed. At this time the freezer and refrigerator slows freezing and cooling, freezer temp. = 30 and up, and refrigerator temp. = 48 and up. It looks like if the reistor is not turning on during the defrost cycle. I measured the resistance and get 35 ohms. I am guessing if the problem would be the module, and if there is any way to force the module go into the defrost cycle manually, to verify if the resistor is burning, and if it is not burning, to check if voltages is reaching the resistor or coming out from the module. Thanks, Manuel Reyes Puerto Rico
  • Manuel Reyes Jul 12, 2010
    Thanks for your help. I appreciate it. I will be working on it.
  • 3,083 Answers
You could possibly modify the module if it were solid state, but that would be more trouble, because you would have to disable one other function, and still be left with a partially working module. The resister will be a current limiting resister, probably designed to open up in case the fan shorts. If the fan is bad, you would not get good readings back at the resister. The condenser fan is also possibly the culprit, but you're right, it could be the control board. If you wanted to for the defrost cycle, you could wire the voltage lead to the fan with a switch. Seems that would be easier than modifying the control board. Good luck, and hope this helps.
Posted on Jul 11, 2010
    I apologize for a misunderstood in the wording when I wrote the problem with my refrigerator. When I was writing the word condenser, actually it is the evaporator the correct part name, which is inside the freezer. Also when I was talking about the resistor, actually it is the defrost heater the correct part name. So if you don't mind, please re-read the problem with the refrigerator taking in consideration the parts that I have mentined in this reply. Thanks.
    Manuel Reyes
    Puerto Rico
Temperature in refrigerator will not stay set. It keeps getting colder. I have a GE Artica model PSS27SGMD. It is a side by side with ice through the door. It is +- 9 years old
GE Artica had problems with the "Motherboards" originally installed. They have since switched manufacturers so my educated guess that is the problem.
Jan 08, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE profile Artica, MDL# psc23mgnabb, ice maker won't make ice, plus refrigerator side is freezing the contents
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 27, 2010 | GE Profile PFS22 33" Artica French Door...
I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
Cut and paste this Factory Service manual for your refrigerator.
The troubleshooting guide will help locate the bad part.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
I have a GE Profile Artica refrigerator that WAS making ice cubes and quick ice until yesterday. What can I do to get the refrigerator to make ice again? The model # is: PSC 23 NG.
if its just stoped dead it could be a number of things
1 the thermostat give up working,,,most likley!!!!
2 the compresor give up working,,,not very likley
3 its lost its gas and needs a regas,,,pigs fly?
try a new thermostat first,,,
Nov 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frozen coils on the Refigerator side.
Make sure the evap fan is running,and the coil should covered for propper airflow
Jun 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
Ice forming on condenser copper tubing GE referigerator
is your drain line plugged up under that coil? another thing to check is if the door asket pinched that wold allow ait to infiltrate into the freeze and freeze up the coil. remember to clean under the unit once a year to keep the unit working properly and not having to struggle to condense the refrigerant. Hopt this solution's work for you and have a Happy New Year.
Jan 05, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
