Question about GE Washing Machines
ModelWJRE555OH1WW. MACHINE GOING STRAIGHT TO WASH INSTEAD OF FILL UP WITH WATER.
  • GE Master
  • 3,361 Answers
Remove the front panel and check for a pinched water level tube..
OR
the air dome on the side of the washer is clogged with soap.
OR
The water level switch is bad.
Open the control console to find a service manual to show how to open the machine and service the parts.
Posted on Jul 11, 2010
I have a Samsung WA75B7PT washing machine. Having set wash cycle water runs continuously, going straight through, from tap to drain basically, machine never engaging?
This can only be because the drain pump is constantly working. Otherwise the machine would literally fill-up with water.
Turn the machine off & unplug it for an hour.
Then turn it back on & see if it's reset or if it gives you an error code.
I'd suggest that it's probably a failed control-board, but it's unusual to not get a fault/error code from a modern machine, when it has a fault.
Best of luck.
Mar 10, 2018 | Samsung Washing Machines
Why my washing machine..instead keeping the water in! drain it straight way out.
what happens when u move the timer manually? will it spin or wash? if so u have a bad timer if not u may have bad control board
Aug 03, 2014 | Hotpoint Washing Machines
Water doesnt stop when filling washing machine
There should be a "fill control" on the panel of the achine that lets you set the fill limit for wash loads ranging from small to large. Obviously, your fill control is not working
Oct 09, 2012 | Washing Machines
I bought a whirlpool washing machine model no LA6AL7244MW. When I put comforter in, it goes straight into the machine when I fill it to wash clothes instead of staying in there til it's time to soften...
Sorry but I have to ask if you are putting the powder and softener into the correct compartments?
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 12, 2011 | Washing Machines
It won't fill . the water on. the dryer works but no power going to the wash machine??
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 21, 2011 | Frigidaire FLEB8200DS Top Load Stacked...
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My washer machine goes straight to washing and does not fill with water.
The air pressure tube going to the water level valve is pinched.
Open the control panel and move the plastic pressure tube then try the fill again.
If it is not pinched,remove the tube from the pressure switch and blow through the tube to clear any blockage in the air bell on the side of the tub.
If the air bell is clear and it still does not work correctly,replace the water level pressure switch.
Apr 12, 2010 | Washing Machines
Wahing machine will not wash
the entire agitator is not moving during the wash??? or just the top section that looks like a big plastic corkscrew???
or is the unit actually just filling with water, making the motor running noises and going thru the motions of running a cycle yet not actually moving anything within the unit, then draining out as normal??
if just the top section of the agitator is free spinning instead of ratcheting as normal you'll need to replace the agitator dogs if present.
if however the units just filling and draining of water with no inner movement then more likely the drive coupling is bad and needs replacement..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
When starting to wash water goes straight out of
The drain you are putting the drain hose into needs to be at least 30 inches above the floor. You probably have the drain hose to low or laying on the floor for this to be happening.
Jun 09, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
89 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
