Question about HP Compaq nx6310 Notebook
Unable to work, when dual core option in BIOS is enabled
Hi
I upgraded (due the absence of speedstep technology in celerons) my hp nx 6310 notebook by exchanging of celeron M 410 CPU with Intel Dual Core T2250. I read, that this CPU is compatible with Intel 945 GM chipset family, therefore I bought one and installed this CPU. If was in  BIOS-setup enabled the option (dual core processors), after BIOS initialization the computer was unable to start, unable start from DVD, USB, CD...black display, fan was on, and LEDs were too on. Only if  this option is disabled (one core is switched off), the computer can run, but task manager shows only one field for one core.
I tried flash BIOS (by the same version :-) F.0E), but no change observed after enabling dual core option in BIOS. :-(
I think, any driver cannot solve this problem, becauce this malfunction is in BIOS or hardware level. Is this dual core T 2250 CPU unsupported by this motherboard ? Or can be only one core burned out and the other intact ?
Thank you for answer.
3 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: Hp 530 notebook cpu upgrade
It's not posible to upgrade to a dual core, the motherboard is a different design. Keep in mind that the processor, motherboard and memory have a matched frequency. If the processor doesn't match the board then it won't recognize it. Since the board does recognize the T2300, it may be that you need to match the memory in order to get it to boot. Match the memory by going to patriotmem.com and entering the model that the T2300 came from, it will tell you the memory frequency. If the memory matches the processor simply will not work with that board.
Posted on Jun 25, 2008
SOURCE: Cpu upgrade for hp 530 laptop
the chip is soldered to the motherboard an i would not mess with that u will end up with a paper weight
Posted on Jul 18, 2008
Laptop doesnt boot when multi core processing is enabled
By multi core I assume you mean when enabling all of the true processor cores. In your laptop's case it's a Dual Core processor which means there are only 2 phyiscal cores and does not contain HyperThreading Technology (HT Technology) which enables "Virtual processor cores"
Could be caused by a couple of things:
1. Your processor doesn't support multi-core processing which is a possibility given there is no HT technology for your CPU. In which case there is nothing to fix. Even though the BIOS may have this option. You can check to see if both cores are enabled when you have multi-core processing disabled; In windows right click on your taskbar and click on "Task Manager" Click on the performance tab. You will want to count the number of processor displays you see. Refer to this to see what I mean:
The reason I have 8 CPU displays is because I'm running an i7-3820 CPU which supports HT Technology; So I have 4 physical processors cores and 4 virtual processors cores (created by HT Technology architecture)
2. You are running Core2Duo CPU with dual physical processors and have disabled 1 of the 2 cores because your laptop won't boot. This sounds more like you need to update the BIOS on the motherboard or maybe a bad CPU might be the cause as well.
Hope this helps.
Sep 12, 2013 | Toshiba Satellite M505-S4945 PC Notebook
Nx7300 black screen processor update
The motherboard will not support the new processors, one they are dual channel and your motherboard is not, creating a conflict, plus the configuration settup is different and I suspect voltage issues. Sorry! but the motherboard is not siutable for this modification.
Apr 04, 2012 | HP Compaq nx7300 Notebook
Best cpu upgrade
The Gateway MX8738 Notebook PC uses an Intel Pentium Dual Core Mobile T2060 processor.
http://support.gateway.com/us/en/s/Mobile/2007/SonicC/1014366R/1014366Rnv.shtml
{ Look under Specifications, and Components }
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_Dual-Core_microprocessors#Dual-Core_Mobile_processors
Yonah Core based.
Built on the 65 NanoMeter technology. (65nm)
Front Side Bus frequency rate is 533MHz. (FSB 'speed' = 533MHz)
Voltage range it can operate on is from .0762 Volts DC to 1.30 Volts DC
Uses the Socket M processor socket,
http://en.wikipedia.org/wiki/Socket_M
The motherboard chipset is an Intel 943GML for the Northbridge chip, and an Intel 82801GBM for the Southbridge chip.
(The Southbridge part number is Intel 82801GBM. It is also referred to as ICH7-M.
Also scroll down to the heading - Southbridge 9XX and 3/4 Series Chipsets. ICH7-M ),
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core.2FCore_2_mobile_chipsets
Bookmark the above chart, I'll be referring back to it.
This is a motherboard diagram for the technology used for your motherboard, in the Gateway MX8738 Notebook PC,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
Primer:
The motherboard chipset technology used in your laptop is a Northbridge chip, and a Southbridge chip.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge chip handles the faster capabilities of a computer.
Supports the Processor, Ram Memory, and High-speed graphics.
[ High-speed graphics being AGP and PCI-Express.
Does Not apply to anything connected to the PCI bus, or Integrated Graphics.
These are slower processes of a computer, and are handled by the Southbridge chip ]
The Southbridge chip handles the slower capabilities of a computer;
Anything to do with the IDE bus, SATA bus, USB bus, Ethernet, and Audio. (Sound)
Therefore you want to look first of all at what processor socket it has, what processor was already installed, and what the Northbridge chip is.
1) Socket M processor socket.
Your replacement processor has to fit in a Socket M processor socket.
2) You know that your BIOS supports an Intel Dual Core processor, and the Yonah Core technology.
The replacement processor has to have a 533MegaHertz Front Side Bus. (533MHz FSB)
Has to operate with .0762 to 1.30 Volts (DC)
3) The Northbridge chip is an Intel 943GML.
Looking at the chart you can see this Northbridge chip will support;
A) Celeron M (Eeech!)
B) Core Solo (Bleech!)
C) Pentium Dual Core
In the list the Pentium Dual Core is the best option.
{ The Celeron M has HALF of the L2 cache that a comparable Pentium M would have.
The Core Solo is just a glorified Pentium 4. It's a Single core processor }
Has to be a mobile Pentium Dual Core that uses a 533MHz FSB.
Based on the Voltage, FSB, and processor socket used (Socket M), the Intel Pentium Dual Core
model T2130, is the best processor your motherboard will support.
What are we talking about here?
You would be going from a processor that operates at a maximum frequency rate of 1.60GigaHertz, to a processor that operates at a maximum frequency rate ('Speed') of 1.87GHz.
Not enough of a performance boost to waste your hard earned money, or time on, IMHO.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 25, 2011 | Gateway MX8738 Notebook
I have a dell inspiron 1545 which has caused me nothing but grief since my purchase in june09 a cousin has given me his old hp pavillion zt 1170. the dell has vista and the pavillion has xp which is the...
Considering the specs:
Pavillion zt1170:
Intel Mobile Pentium III-M processor (starting at 933 MHz) with SpeedStep technology. –or– Intel Celeron processor (starting at 866 MHz).
Inspiron 1545:
A minimum of an Intel® PentiumTM Dual Core
There is no comparison between the computers,.. Keep the dell and work out the issues or sell it and use the cash towards an inexpensive new unit.
I hope this helps
Feb 07, 2010 | Dell Computers & Internet
F672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Sep 05, 2009 | Acer Computers & Internet
Toshiba Satellite M45-S169 CPU Upgrade
the chipset will support pentium M processors and some pentium 4 notebook processors. the bios should recognize the processor's new speed and should be able to support a 533mhz fsb. as long as your celeron is not soldered to the socket, you should be fine with the upgrade.
Dec 24, 2008 | Toshiba Satellite M45-S169 Notebook
Cpu upgrade
Your computer has one of these options:
spacer.gif level2_arrow.gif Intel® Celeron® Processor 560
(1MB L2 cache, 2.13GHz, 533MHz FSB)
or
Intel® Celeron® Processor 550
(1MB L2 cache, 2.0GHz, 533MHz FSB)
or
Intel® Celeron® Processor 540
(1MB L2 cache, 1.86GHz, 533MHz FS
or
Intel® Celeron® Dual-Core Processor E1400
(512KB shared L2 Cache, 2.0GHz, 800MHz FSB)
or
Intel® Celeron® Dual-Core Processor T1400
Check the features with Acer first and see if your motherboard model support that speed processor.
Contact tech support directly to the manufacturer right here:
http://acer.custhelp.com/cgi-bin/acer.cfg/php/enduser/ask.php?p_sid=8P57rbgj
Oct 13, 2008 | Acer Aspire 5315 Notebook
Upgrading my laptop's processor to a lower processor
No laptops graphics are integrated into the motherboard and cannot be change with any bit of ease
Aug 10, 2008 | Acer Aspire 5100 Notebook
Jun 25, 2008 | HP 530 Notebook PC
HP Compaq nx6310 Notebook Logo
181 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
