Question about Apple eMac G4 Desktop
I turn on computer apple sign comes on and a
I turn on g4 emac computer, apple sign comes on and a little circle is turning likes it loading but wont go anywhere else just stays like that
    President:
  • 2,571 Answers
I have no experiense with apple/mac products, but you may be able to boot up into safe mode and do some system repair.
There is a guide here http://support.apple.com/kb/ht1455
Posted on Jul 11, 2010
G4 Desktop wont load, all i can see is a question mark flashing on and off in the centre of the screen
Try booting it into single-user mode holding down Command(Apple) and S buttons when powering up. Then in terminal console, use chkdsk -fy. Use it and use it again until comes back with something like "Volume appears to be OK". Then use command: mount -uw / and then type reboot and try booting normally.
-juuko
Nov 18, 2010 | Apple eMac G4 Desktop
Why is there no display on my Apple eMac G4 desktop?
Have you tried turning it on and off again?
Oct 20, 2010 | Apple eMac G4 Desktop
Screen stays black when i turn on mac g4 desktop
Have you had any screen problems leading up to this? Things like random freezing while moving the pointer or dragging a window, or disturbances to the display like tearing or jaggy edges appearing randomly?
If so then you probably have a faulty motherboard caused by the infamous leaky capacitor problem. This was a world-wide problem but it appeared to hit the eMac particularly badly. You can check it by opening the little panel on the bottom of the eMac (small cross-point screwdriver and 1 screw) and have a look at the capacitors inside. You can see 3 or 4, they are silver cylinders. If they show signs of bulging or any gloop oozing from them then that is the problem. It is repairable but Apple will probably tell you to take it to a repair centre as they don't carry the spares anymore.
Best option is to try a TV repair man as the skills needed are more TV repairman than computer tech related. However - big problem is that given the age of the eMac, there is a good chance that the gloop will have caused corrosion on the motherboard - and that is NOT repairable.
Be prepared that you may have to buy a new Mac. Your data is safe on the HD as that will not be affected - get the TV man to take the drive out for you - the high voltages inside can kill - (better kill him than yourself) and then install it in an external case to run on your new Mac Without being with the machine it's difficult to determine any other problem that it could be.
Nov 09, 2009 | Apple eMac G4 Desktop
Mac not loading
Try resetting your pram:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Aug 28, 2009 | Apple eMac G4 Desktop
MAC G4 won't boot - Blue screen appears
Hi Sorry to hear you are having troubles,You will need a firewire 400 cableOK, first thing you must do is reboot the eMac in TARGET mode, this means it will be recognized as an external disk. To get the eMac in TARGET mode, you must be sure the eMac is turned OFF and has a functioning keyboard connected.Power on the eMac and very very rapidly press the ( T ) key on the keyboard, be sure the caps lock button is not pressed. If all goes well, you will see the firewire logo appear larger than life on the screen.( If you are unable to get into TARGET mode, it is highly probable that the mother board of the internal hard drive is damaged and preventing the eMac from entering TARGET mode, sorry, that's the end of the line..)Once you enter TARGET mode on the eMac, connect the firewire cable to your G4 PowerBook, you can do this either while it is running or when it is off and then turn it on.
You should see the volume of your eMac internal hard drive appear on the PowerBook desktop...sometimes you need to open Disk Utilities and repair or mount the drive manually.If this all works well, copy the required files directly to your PowerBook...After that, power off both machines, disconnect them and reboot the eMac using a CD or DVD to reformat and reinstall a new system.
Mar 30, 2009 | Apple eMac G4 Desktop
Network a G4 (OS 9) to a eMac (OS X)
OK - first, crossover cables let you network PCs together without a switch or router. I would strongly recommend returning the crossover cable and buying a router so that you can use both computers on the internet at the same time.
Second, the eMac monitor can not directly be used as a monitor for your G4 - it's not built that way. However, you can use Screen Sharing on OS X (if both have Leopard) or Apple Remote Desktop software (if you buy it) to remote control the G4 using the eMac.
You will DEFINITELY need a monitor on the G4 in order to set it up at all, so I hope you have that.
Keep in mind that you can buy, for less than $200, an LCD screen that is larger and better quality than the eMac, and it would leave the eMac useful as a second computer. Since the eMac is unlikely to work at all with Leopard, and you'd have to buy Apple Remote Desktop, you're going to spend less money by buying a separate screen for the G4.
Nov 22, 2008 | Apple eMac G4 Desktop
EMac G4
Did you try pressing F14 or F15?
Jerry
Jun 01, 2008 | Apple eMac G4 Desktop
Flashing apple
The flashing question mark / picasso face means your com puter cannot find a bootable volume or start up disk. Basically, it cannot find your operating system to load. That could mean a few things. Mainly it means your hard drive has failed, and is not performing properly, or cannot be detected. It could also mean the bootsector of the hard drive ( where it wrote os x when it was installed ) has bad blocks or sectors, preventing it from reading the disk correctly. if the hard drive is anywhere from 3 -4 years old or older, all of these options are likely. YOu can try to power the computer on holding down the OPTION key. THis will boot your machine into start up manager. Also try this procedure with an OS X cd or dvd inserted. If you have another macintosh running 10.3 or later, that has a firewire port, you can boot the emac into target disk mode by holding down the "T" key. The other mac should be on , and hopefully the emac will appear on the desktop fo the other computer. THis allow you to hopefuly recover the contents of the emac.
http://docs.info.apple.com/article.html?artnum=58583
http://en.wikipedia.org/wiki/Target_Disk_Mode
Hope this helps, KEEP ME POSTED.
Jan 15, 2008 | Apple eMac G4 Desktop
Apple eMac G4 Desktop Logo
136 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
