Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
I need a diagram for the drive belt on a 16hp 38in cut poulan riding mower.
  • 32 Answers
SOURCE: what size drive belt does a 38in deck require?
it depends what kind of mower you have, i have a 38'' mower that uses a 14'' belt.
Posted on Jun 12, 2009
SOURCE: my poulan riding mower goes dead whether cutting
I had exactly this problem the carb looked clean, but was clogged it was fine after a rebuild. a lil adviceput a shut off valve between the tank and fuel filter. it'a a really eay way to make changing the fuel filter easier plus you can run the carb out of gas for storage. an empty carb never clogs up
Posted on Aug 07, 2009
2strokeguy
  • 183 Answers
SOURCE: what is the deck drive belt length for this mower
Your mower uses the #144200 belt by A.Y.P. This belt is 1/2" by 88.3" You must use a wrapped belt for this application. The #144200 is available through www.searspartsdirect.com and will also be readily available at your local repair shop.
Posted on Sep 10, 2010
  • 640 Answers
SOURCE: need to fine out if
Are you asking what size belt to use or are you asking what other size belt, like you want to use one a little smaller or a little larger? If that is the case, what difficulty are you having that you would need to do that? Did you put a Craftsman deck on a Poulan or something odd like that?
Posted on Aug 07, 2011
  • 2572 Answers
SOURCE: how to adjust tighten drive belt on Poulan riding mower with 18 hp b&s motor 42 deck
Probably needs a new belt.You can buy a belt dressing and spray the belt once in a while. Its a special sticky spray for belts that slip.
That will keep you going for a little while.
Posted on Apr 11, 2015
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
Belt size for 616 deutz allis riding mower ,deck & drive
most wear parts numbers are on the bottom side of the hood.
Jul 29, 2012 | Garden
Mower deck belt diagram for poulan 42 inch ride mower
Go to Craftsman, Order Tree or Parts Tree.com and input your model number. Choose the correct tab and go to the mower deck. It will give you a good over view of how the belt routes. Hope this helps.
Nov 02, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I need a diagram to remove a drive belt
You dont need any diagrams to change a belt just turn the mower up on 1 side and see where the belt goes and if you want to draw your own diagram and keep it safe But then you will find a idler drive pully on all mowers and that is either spring loaded or a nut and bolt holds it tight,,, and that could be the one that drives when you put the lever in CUT but have a good look and its easy to do..
Let me know how you go Ron
Oct 04, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
What size drive belt does a 38in deck require? just bought a mower with no belt? Thanks
Jun 12, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
35 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
