Question about Palm Tungsten E2 Handheld
My PalmOne Tungsten E2 has a fatal alert "DataMgr.c, Line:8872,DmWrite:DmWriteCheck failed" Is there anything I can do to recover from this
    President:
  • 1,561 Answers
I advice you reset the device, resetting it will help fix the abnormalities and put back the device in place, you are not going to lose any file by resetting it.just reset device, it will fix the problem.
Take care.
Posted on Jul 11, 2010
  • wdevantier1 Jul 12, 2010
    I've tried the hard reset without any solution to the problem. ie. I get the same fatal alert message
Fatal Alert Datamgr.c,Line7564 InvalidUniqueIDPassed I get this when I synchronize.
Perhaps you haven't tried performing a more severe reset to break the freeze. You might want to try doing a hard reset. This will erase all data from your hand held so make sure you have everything backed up on your computer so you can sync it again after the hard reset. Note, when I occasionally receive a Fatal Alert error, the Reset on-screen button almost never responds to a tap...I invariably have to depress the reset button in the back of my E2. http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(26419) resets:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887) Depending on a variety of factors including the available memory on your E2 and other installed applications, the problem might or night not be caused directly by the program you were trying out. But once you get the E2 unfrozen, you should refer to this article to troubleshoot the cause of this apparent software conflict:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908) Also, I recommend going to the developer of the software you are using, to determine whether there are any compatibility issues at their end, and whether they have an upgrade available.
Here are the directions for the hard reset.
1. Press and hold down the power button.
2. While holding down the power button, use the tip of your stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear and then release the power button.
4. When you see the message that warns you about erasing all your data please continue and then follow the on screen directions.
If this doesn't help then I recommend going to www.palm.com. From there you will need to select PDA's and then the model of yours. It will go to another screen and you should be able to contact palm via free chat. I have had to do this several times and both times I got fast service. Hope this helps.
Aug 24, 2009 | Palm Tungsten E2 Handheld
My Tungsten E2 has a fatal alert message: MemoryMgr.c,Line:3732,Null handle
Sounds like it has something to do with its RAM i would see a phone/computer repairer i have herd of this in a few other devices like this having these faults it called a random acess memory DUMP! and the ram chips start playing up and the device loses its random accessable data......have you noticed it get slower over time??? i would take it for repair!
Aug 13, 2009 | Palm Tungsten E2 Handheld
Tungsten e2
Take a look at your address and birthday sections and see if you can find duplicates bith in your PDA and you desktop.
Jan 05, 2009 | Palm Tungsten E2 Handheld
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Nov 09, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 error
Everytime I got that error, press soft reset on back and it should reboot normal
Oct 12, 2008 | Palm Tungsten E2 Handheld
Unable to hotsync with my computer
anytime you get fatal alerts you have to do more than just push the reset button. You will have to do a soft reset or possibly a hard reset,(usually the soft reset works) Google it and you will find it is quite simple to do
Jun 17, 2008 | Palm Tungsten E Handheld
Fatal Alert
Though Docs to Go is supported by Palmone, it is still a 3rd party software and will jam your unit like you wouldn't believe. I reloaded mine 15 times before I gave up and quit using it. The Fatal error is an all out jam. The Docs can even duplicate themselves and yes you end up dumping the program from your e2 and reloading before it will work again. The e2 is good and I made mine do internet wirelessly but could never whip Docs.
Mar 03, 2008 | Palm Tungsten E2 Handheld
Fatal Alert problem
We prayed and asked God to save the data even though we had to do a hard reset. Data was preserved entirely! For this we give thanks--and praise.
Rob Starner
Feb 19, 2008 | Palm Tungsten E2 Handheld
Fatal alert [Memory Mgr,C,Line:3751, Free handle
Thoroughly flush (delete) documents to go using the tool below and then reinstall.
Worked for me two times over the past two years when my E2 has gotten sick.
http://support.dataviz.com/support.srch?docid=13445&pid=2000
Dec 01, 2007 | Palm Tungsten E2 Handheld
Also, if you have a new Tungsten E2 and there is no important data, I would hard reset it and then when you sync it, select the old profile of the previous Palm to see if that works.
The new Palm you have, is it a Tungsten E2 as well?
The profiles don't always carry over between different models.
Sep 07, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E2 Handheld Logo
77 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
