Question about HP iPAQ hx2410 Pocket PC
My Ipaq is stuck
I have this model Ipaq and I thought from the beginning that something was wrong with it, but I thought maybe is me, the user. Now I can not turn it on. Actually, I can turn it on from the on/off button on top, but I have it only turns on and never gets to my password sreen no matter where and how I touch the screen. It seems like the screen is stuck. I like these PDAs, they do what I need them to do for me, but the operating system on them simply is TERRIBLE. The fact that now I have the feeling is nothing I can do to turn it on anymore and the fact that I did not get a chance to back it up recently, means that I am going to loose everything on it in the event I have to maybe take the battery out to try to turn it on that way. This PDA I have the minute I take the battery out it resets and erases everything on it. It seems like the back-up battery does not play a role ast all. By the way, what kind of system is that of loosing everything if you take the battery out? These PDAs are practically similar to the phones and I do not understand why it has an otion of changing the battery if you have to reconfigure it every time you put a new battery in. This is beyond my understanding and makes this item very faulty, wouldn't you say so? If I can not ever turn it on without loosing my info on it I will never use a PDA again and I am willing to smash this one to wall, I am so upset.
I hope you can help me because I am very sad at this moment and I have a lot of work in it in which I put a lot of time and I will be very sad if I loose it.
Thank you so much and I hope you understand my frustration.
Sincerely,
Daniela Geana
Bogdan
  • 198 Answers
SOURCE: Ipaq 4155 wont turn on, dont charge, dont anything, is totally death
I had some similar experiences with these ipaq's when I was working in a specialised service center. I'll try to give some help or tips through the internet, altrough if i could have seen or diagnosticate these pda's myself it would have been more easier. First of all these problems have 2 main causes. Most of the pda's comply with one of them, it is very rare that a pda will develop this problem by having both causes.
The first cause is the hardware one. A component called the main voltage convertor is broken. It's a small chip that uses the voltage given by the main battery to convert it's value to various tensions required by some of the components on the pda's main board. If some sub-parts of this chip fails to work, the result will appear as the problem you face, In this case there isn't much to do. Most service centers will replace the whole mainboard because that particular chip is very hard to find as a replacement and difficult to desolder from the board.
The second cause could be a major firmware / ROM memory corruption. These things can happen out from nowhere. In my time working for service centers I've tried to isolate a pattern for this problem but without much succes. However it seems that most of these problem tend to appear durring charging cicles due to power spikes or drops on the main AC voltage supplied to the charger. This is only a supposition, I'm not sure yet on this cause. What to do here? Well this problems are fixable but first of all you must be sure that this is a software problem, not a hardware one. So let's diagnosticate some things.
Try to charge the pda. Ignore any lights or beeps or whatever your pda is showing on the screen. As long as the charger is connected the charging process is based on the most primary charging circuits on the pda's motherboard. If the pda is not charging or cannot hold any charge (when you unplug it the screen fades away or it simply doesn't do anything else) maybe that circuit is broken (this is a a sign of serious hardware problems ) or maybe the battery is to old/weak. Batteries don't die out of nowhere, if you remember your pda to work and have some 2-3 hours of standby time it's imposible that now, suddently the battery has drained out so much that even if charged it can't hold out at least 30 min.
So we will assume that you charged the pda for at least 2-3 hours and you see some sign that the battery is working. The next step is crucial. TRY TO PUT THE PDA IN BOOTLOADER MODE. You will achieve this by pressing (and keep them pressed!) the following buttons : power, the far left and right buttons near the control pad (joystick or whatever some people call it) and reset button. You may need another person to help you press these buttons. the order should be the following (first power, then the 2 keys, then reset button for as long as it takes to enter bootloader mode). YOU SHOULD SEE A WHITE SCREEN WITH THE HP LOGO.
If your pda fails to do that, there is nothing more you can do to restore it in a DIY fashion. Probably the bootloader is corrupted or you have a hardware fault. Only a specialised HP service center can help you now. In most cases this will end up with a motherboard replacement.
If your pda does that, then there is a chance to fix it. We will need to probe the bootloader for direct data acces. This is needed for having the ROM memory (and operating system) rewritten. A small program called Mtty will be required to access the bootloader via an usb link.
Please make this tests first and then reply with your results. If anyone of you is in situation #2 there may be a chance.
Posted on Feb 10, 2008
SOURCE: ipaq hx 2110 - will not go past align screen after hard reset
I punched it in the *****
Posted on Apr 09, 2009
erincinci
  • 148 Answers
SOURCE: not turning on
Hi there, I think you pressed some more buttons and accidentaly you entered your device into Serial Mode (Bootloader), which you should update your ROM or reinstall your existing ROM in order to exit that state. I am sending you a link to HP website including your device's ROM upgrade download link, and a complete list of instructions. First of all, connect your device with a usb cable to your PC and see the "USB Mode" in the screen of your PDA. Also please be carefull and read the instructions very carefully before starting the process. Here is the link: (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?swItem=ip-55697-1〈=en&cc=us&idx=0&mode=4&) Hope this helps. Have a nice day.
Posted on Apr 20, 2009
WiFiNut
  • 53 Answers
SOURCE: Hp Ipaq hx4700 - Cannot get beyond 'Align Screen'
I have had this problem on other Windows Mobile devices. You must press *firmly* at each point.
Posted on Jun 30, 2009
SOURCE: IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
Posted on Jan 02, 2010
Small food particles getting stuck
Check your drain filter and clean them. refer user manual for location
Apr 06, 2010 | GE Nautilus 24" Built-in Dishwasher
How do i put the unlock code in a ipaq rw6828
On the start up screen when the phone say's 'wrong sim' or some such. type in the unlock code. Usually it begins with a pw the can be attained be repeatedly pressing the * or the # button's.
Jun 30, 2009 | HP iPAQ rw6828 Smartphone
Toochscreen stop responding on HP iPAQ hw6945
Hi!... Maybe you forgot to install the plastic membrane attached in the front housing?... Check it maybe you forgot to install it...
Jun 19, 2009 | HP iPAQ hw6945 Smartphone
Hp ipaq 5550
To do a full reset, you hold the calendar and itask buttons (buttons 1 and 4) down at the same time, then insert the stylus into the little hole on the bottom and press gently. Hold all for 4 seconds. The screen should begin to fade. Now release all. If successful, you will not be able to start the machine by pressing the on button. You will have to reconnect to ac power to start it.
That is all there is to it.
Jan 24, 2009 | HP iPAQ H5550 Pocket PC
Need a users/service manual for a compaq ipaq legacy-light
this is as close as i could get for a service manual, something similar here might work
http://www.gadgetsmanual.com/technical-reference-guide-compaq-ipaq-series-10-12-and-20-models-manual.html
Dec 06, 2008 | Compaq iPAQ Legacy-Light PC Desktop
IPAQ 210 Stuck on Boot Screen
A "hard" reset work.  I thought I tried this earlier but I was pressing the wrong keys.
Aug 31, 2008 | HP iPAQ H2210 Pocket PC
Pc doesnt see ipaq h6315
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Apr 19, 2008 | HP iPAQ h6315/h6365 Pocket PC
My ipaq would not start
Hello gonchero, Can you please specify which model Ipaq you have? (I'm not familiar with the Ipaq 2003, so I think you're referring to the Operating System version, or something along those lines). Either way, a 'Hard Reset' will probably get you back up and running. Once you tell me which model you have (located on the back of the ipaq), I can give you the steps for doing a hard reset for it.
Apr 06, 2007 | Compaq MS Pocket PC 2002
HP ipaq h6320
Here is a link to the full manual, however it says right in there to not disassemble so you will probably have to find someone's who has done it (maybe on a PDA or Ipaq forum) and ask them for direction. http://user-guides.mobiletopsoft.com/hp/hp-ipaq-h6300-series-user-guide/hp-ipaq-h6300-series-user-guide.php
Mar 28, 2007 | HP iPAQ h6320 Pocket PC
Updating ROM
The HP 6515 came in various instances from A through F from memory. you need to ensure you have the update for the right instance of the device. Under the battery is a sticker with the information you need, or maybe in the device config screen within the OS
Nov 15, 2006 | HP iPAQ hw6515 Pocket PC
Open Questions:
See all HP iPAQ hx2410 Pocket PC Questions
HP iPAQ hx2410 Pocket PC Logo
56 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
