Question about Dell Inspiron E1705, Intel Core 2 Duo T5300 , 17" WSXGA+ LCD, 1GB DDR2 SDRAM, 256MB ATI V... PC Notebook
I closed the lid thout turning off the computer. The next day when I opened to top it was off. When I turned on the computer the two lock lights with "A" and "down arrow" lock lights started blinking. I did not do anything I know of to lock the machine. How do I unlock it
    Scholar:
  • 135 Answers
Hit the Spacebar until it comes back on. you need to change settings in you power management to fix this.
Posted on Jul 12, 2010
My washer sensor turns on and then the lid light starts flashing and the washer will not turn on. What is wrong with it?
What is the model number listed on the unit?The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
Nov 18, 2012 | Maytag Centennial MTW5800TW Top Load...
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Everytime I lock my computer,shut the lid or leave it untill it goes black, it will not come back on when I touch the mouse pad. However when I got this laptop it worked and when I opened the lid and...
Well by default Closing the Lid will cause computer to go to Sleep mode and you can't wake it up using mouse. However you need to press power button to wake it up.
But as you said it was working the way you explained then seems like Power settings on your computer are changed
To check the settings Got0 -Control panel and click on power Options Goto - Advanced and find the Lid open/close actions You can change it there If you don't want your computer to goto sleep mode with the lid close, you can simply disable it.
Hope this worrks
Jul 14, 2011 | Computers & Internet
How do you lock it?
Hi Celsa,
Please follow the below instructions to unlock and lock depending on the series of sentry fire safe security you have.
H & F Series:
To unlock and open:
1. Insert key in lock and turn counterclockwise.
2. Apply downward pressure on top of the safe, while
pushing the latch in to release.
NOTE: Due to compression of the gasket, the
unit will require slightly more force
than a safe that does not have a gasket.
To close and lock:
1. Close and press down on lid to engage latch.
Safe can now be transported without locking it.
2. Insert key in lock and turn clockwise.
HD & FD Series:
To unlock and open:
1. Insert key in lock and turn clockwise.
2. Pull up from bottom
of latch while pushing
down on lid to release.
To close and lock:
1. Close and while pushing down on the lid, press down on
the latch until it is secure.
2. Insert key in lock and turn counterclockwise.
For the complete manual with images you can click on this link :- http://bit.ly/lzdBP2
Hope this helps.
May 11, 2011 | Sentry 1110 Fire Safe Security Chest
My Roper Washer RTW43405Q0 won't spin.
For the washer to operate the lid must be fully closed, the timer must be pulled out, and the water must be drained.
The main causes for not spinning are:
  • Lid partially or completely open
  • Lid or other object has hit the timer knob and turned the washer off
  • Lid not locked (by the way, not on all washers) and may be not draining.
    Make sure the lid is completely closed. Make sure that no clothing is in the lid area.
    Make sure the Timer knob is pulled out.
    The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
    Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
    If the washer has not drained, it will not go into spin.
    Hope this works.....
    May 01, 2010 | Roper RTW4300SQ Top Load Washer
    Remote key will not open door
    hi, gareth hear
    i think this mite work 4 u
    get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
    next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
    this will work 4 u!!!
    good luck
    Dec 14, 2008 | Code-Alarm Code Alarm Transponder
    I just bought a docking station for my Dell laptop computer. How do I hook it up so I can keep the top closed and use my desk top monitor? I want to be able to turn on the laptop without opening the lid.
    Well.. you'd still have to open the lid to turn it on, right? (because you didn't mention the model of your laptop, I don't know where the power button actually *is*)
    You want to close it while it's on, without it hibernating or going to sleep...
    Go to your control panel, then into power or power management (depending on your Windows version, because you didn't mention it)
    Then have a look under the "advanced" tab where it asks "when I close the lid of my computer". Set that to "do nothing".
    Now when you close the lid, the laptop screen should turn off, but the PC should keep running. I'm not sure if that will still turn your external monitor off though.
    I think that is your best solution, other than hacking off the little button that senses when the lid is closed. =-]
    Aug 23, 2008 | Computers & Internet
    Sony dvd camcorder DCR-DVD201E Lid not closing
    Most often, in this case, the locking relay has failed. Sony has an improved part for this. It requires a Sony qualified servicer. I have replaced them before. Good luck, magic seadog
    Apr 06, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
    Dell Inspiron E1705, Intel Core 2 Duo T5300 , 17" WSXGA+ LCD, 1GB DDR2 SDRAM, 256MB ATI V... PC Notebook Logo
    113 people viewed this question
    Alun Cox
    mukhtar21 shaikh
    mukhtar21 shaikh
