Question about LG DU-42PX12XC 42 in. Plasma HDTV
My tv has black solid line
My tv has started getting a thick solid black line down right hand side of screen. will go on its own after a while but does return.
IHi Dicrewsmith, I am having the same problems with my flat screen Tv, it comes and goes too, though is seems to have made it's self at home as of late.
I can't help you , but was hoping that you may have found a solution to yours, as I am having trouble finding stuff here.
Hope you can help
Kris
post here or and to paul63au@bigpond.com
Posted on Jul 28, 2010
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Ive got a line down the left hand side of the screen when the tv is turned on the model number is panasonic viera tx-p42v20b
HI,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
GOOD LUCK IN RECTIFYING THE FAULT, THANKS
May 13, 2011 | Panasonic Televison & Video
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Pioneer PDP-425CMX 42" Plasma Tv
Try the scan PCBs that run down the side and the connectors that hook them up to the rest of the system. That would be my first place to start.
Unfortunately I don't have service manuals for non-european models. What is the date of manufacture?
Nov 16, 2007 | Pioneer PDP-425CMX 42 in. Plasma...
Sky 42 inch plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Sep 06, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Hyundai 42inch plasma tv
If these are thick black lines, this is most likely line frequency noise entering the set. you may have a leakage from the DC ground on the secondary side of the powersupply to the AC side, or a bad filter capacitor(s). Most of the time it is the filter caps that give these types of problems. If you are connected to cable TV service, or an outside antenna you can also have this problem from an AC ground loop return. Also if there is a device such as a VCR connected to the TV and it has problems, it can cause this as well...
Mar 20, 2006 | Hyundai ImageQuest DPD4210 42 in. HD-Ready...
LG DU-42PX12XC 42 in. Plasma HDTV Logo
265 people viewed this question
Computer Repairing
Computer Repairing
