Question about Soyo DYLT032D 32 in. LCD Television
Remote problems Remote for tv does not work. The light does not come on. I have changed the batteries
  • 11,361 Answers
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 11, 2010
My remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Take the remote to any working radio, change radio band to SW, press various buttons of the remote and if you can listen to some clicking noise on the radio, the remote is ok. The problem might then be on the sensor and might need attention by a qualified service technician. You can also try switching off the TV, removing the plug and retry after 48 hours.
Aug 02, 2012 | LG Televison & Video
Sharp remote quit working. Lights turn on, could it be the tv's problem? Ga724wjsa
Another way to verify if the remote is working is use your phone or camera to look at the IR eye of the remote while pressing a button you will be able to see a red light everytime you push the buttons to make sure the remote isnt just faulty. For any Sharp TV do it yourself TV repair call us in Centennial, Colorado.
Jun 02, 2012 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
My TV remote doesn't work. I changed the batteries but that didn't solve the problem.
The remote can be tested and Radio Shack and most repair shops have a simple card for testing---point the remote at the card and press buttons and the strip on the card either lights up or not.
Depending on the problem most remotes are fixable.
Stay away from "Universals" as they are usually trouble.
If batteries and remote test good the set has a receiver for the infrared signal the remote sends-
95% of the time it is the remote and not the receiver or set.
A precise model number would tell me of common issues with your set including the remote.
Mar 14, 2012 | Televison & Video
My remote does not work on my tv I have change the batteries but I notice that thre remote control sensor light does not blink or the OPC sensor. We have to turn on the tv manualy and to change channels...
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Good luck.
Mar 02, 2011 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
My tv remote doesnt work from a distance i have to go very close to my tv for it to work, i have changed the batteries though.
There are several possible reasons. The light-emitting end of the remote, or the remote sensor window on the TV, may be dirty. The light-emitting diodes in the remote may be misaligned from dropping the remote control, or they aren't putting out as much light as they should. The TV may have another light source shining on it that prevents it from picking up the remote signal until it gets very close. The remote sensor in the TV might be bad. Or there may be an interfering signal. As more people start using compact fluorescent lamps (CFLs) in their homes, they sometimes find that remote controls begin acting strangely. It's also possible the replacement batteries you put in are weak, so you might try another set.
Sorry I can't tell you which of these is most likely. I've seen them all many times. Try another set of batteries first, then try a universal remote to see if the problem is in the TV or the remote.
Good luck! Hope this helps, and thanks for using Fixya!
Jan 31, 2010 | Emerson ET-20F7 19" TV
REmote control RM-C1257G not working even after trying new batteries
Try this
1. Get camera phone
2. set camera phone to to take picture
3. point remote at camera and look at the camera display
4. press buttons on the remote, you should a light from the Remotes IR.
5a. If NO light is seen, your remote is broken. you can try replacing the batteries to double check
5b. if Yes, light is seen. Your remote is working and you may have a problem with the TV.
As a double check, get a remote you know is working and try the same thing to verify that you are checking the remotes correctly.
May 27, 2009 | JVC LT-26X575 26 in. LCD HDTV
Remote won't work
hi, see if the right funtion is selected, tv, vcr, dvd.then if that does not help, get a universal remote. they don't cost alot or some don't good luck. hope this helps.
Apr 15, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Remote won't work
I would try 'waking up' the remote-Take the batteries out,press each button once then put the batteries back in.See if that works.
Jul 24, 2006 | Apex Digital AT2014DV 20 in. TV/DVD Combo
Soyo DYLT032D 32 in. LCD Television Logo
63 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
